ITS 15 O12's Prestige: english Vs spanish (again)
Discussion in 'ITS' started by xagroth, Dec 20, 2023.
  1. xagroth
    So yeah, here we are again.
    In the last patch to the ITS, the O12's Prestige rule got a limitation, regarding Tactical Sense. The problem comes from comparing the two versions
    Spanish:
    English:
    Dunno who thought "available" means the same thing as "containing", but the problem here boils down to Tactical Sense being an Automatic Special Skill (so it's always "on", like being a Specialist Operative, for example), and how one of the effects of Unconscious is that the troop in such state has all gear and Automatic Special Skills "turned off" (yes, the troop still "has" the skill", but keep reading), and how that means, in Spanish, that the troop is not "available".
    Meanwhile, the english version states that O12's prestige gets blocked as long as a troop with the skill is in the group, meaning you need to refer to a FAQ stating that a troop only leaves a Combat Group once Dead, Sepsitorized, or moved using a command token/Strategos, while Unconscious troops still belong to the same combat group.
    So, it would be nice if the wording would be consistent between translations, frankly.
    @HellLois can you or Koni look into it? (I think it was you the one looking over ITS documents)
  2. xagroth
    Also I just stumbled upon a quite disturbing difference between the english and spanish Objectives deck:
    English: BS Attack (ORA or Short Order allowed):
    Spanish: Short Order (Orden Corta) demanded:
    Now, the problem would be cards like Data Scan (since HVT's won't generate ARO, and an Unconscious enemy troop shouldn't either, making Nanoespinage merely not detailed...)
    #2 xagroth, Dec 21, 2023
    Wizzy likes this.
