1) There is an inconsistency between en and esp ruling in Dominant Master Breacher. In the description of the rule in the spanish version there is a sentance "Si al final de la partida" (at the end of the game), but the eng version has no one and scoring table for both langs instruct us to score for Dominant Master Breacher for each game round. 2) Even with scoring DMB only at the end, it's possible to score 11 points: 2 for activate two coffings 4 for dominate both HVT QUADS, +1 for 1one of the dominated by Master Breacher 2 for classified and 2 for Threating both HVT with Master Breacher, couse it's posible to threat both if HVT are spawend verticaly as it's only 6" for quad boarder from HVT if Dominant Master Breacher should be scored each round, it's even posible to 13 points.
You cannot threaten the HVT in a zone you already Dominate. You either score 2 pts for Dominating the Zone, or alternatively can score 1 point through a Threatened HVT. The word "alternatively" is missing for the MB Threaten, but I assume Threaten with the MB also falls under the Threaten rule that if you Dominate already Threaten doesn't work. However, this still leaves us with 11 points if MB scores at the end of Round or 9 if it is end of Game 2 Activate Coffins 2x2 Dominate Zones 3x1 Dominate with MB 2 Classified
I guess the calssified should be 1 pts, that would solve it and leave the emphasis on the positioning aspect of the mission (Plus with secure HVT workaround to classifieds lessens the effect you can get by simply standing by the same HVT) @HellLois ?
Thanks a lot!!! And Threating with MB should be alternative to Dominate with MB, same as threating by itself is alternative to Dominate, right? Or domination with Master Broacher should be only once on the end (like in spanish description of dominate master breacher block) but Threatening with MB counts when you dominate? Both will bring us to 10, and as there is inconsistency in translation, could you clarify?
Threating HVT does not count if you already Dominates the Quadrant containing the HVT. You can dominate a Quadrant without an MB, but you need to dominate a Quadrant with a MB to get a Dominat MB point.
