Issues with Army Builder program
Discussion in 'Infinity Army' started by Arkangel, Nov 10, 2019.
  1. Arkangel
    Arkangel Bringer of Justice, Avatar of Retribution
    Greetings all,
    I've run into 2 glitches and am not sure how to report them concerning the Army Builder program. I discovered these when I purchased Op: Wildfire. The first is that the Gwailos, which appears on the general Combined Army list, does not appear in the AB except in the Shasvaasti sectorial army. The second is Carmen Johns profile displays but you can't add it to anything. The link is completely dead.
    If anyone knows about this and has some useful info such as when/if it will be fixed, I would kindly appreciate it.
    Thank you,
    Arkangel
  2. colbrook
    colbrook Black Fryer
    Gwailos are AVA 0 in Vanilla CombArmy so don't show in the Army Builder.
    Arkangel and chromedog like this.
  3. toadchild
    As far as I know, Gwailos are meant to be exclusive to Shasvastii Expeditionary Force.
  4. colbrook
    From the Daedalus' Fall profiles PDF:
  5. colbrook
    Are you using mobile, desktop, or App? I just tried it and I could add Carmen & Batard on both mobile (Chrome) and Android app without issue.
  6. Arkangel
  7. Arkangel
    Looks like they need to update version 4.2 of the army lists. It shows an AVA 2 with a footnote for one of the lieutenants.
  8. Arkangel
    That's what I figured as well, but so far it's the only Shasvastii unit that is. V4.2 of the Army Lists shows it in the plain vanilla roster. But that's clearly been changed. See if it's included in the generic CA force, I actually can field a 300 pt force. Otherwise I have an odd miniature or two left out. I hope Corvis Belli update the army list soon.
  9. colbrook
    I just tested the Chrome/Android Web version, tapping on the highlighted area adds them to my list. What browser/OS are you using?
  10. colbrook
    The profiles in the v4.2 PDF have been superceded by the ones in the Daedalus' Fall profiles PDF, you might also note that the Gwailo has been given a significant revision between the two (it's now an HI, has Albedo, has extremely different weapon options) to the point where it's essentially a completely new unit.
    Army is correct at this time as the current Gwailo is not available to Vanilla CombArmy.
    @Bostria @Koni @ijw is it possible to update the profiles PDF to show which Shasvaasti profiles were replaced in Daddy's Fall? (if you have any time to spare from Defiance insanity).
