Quick one - if I want to use a command token to convert the irregular order of a Hardcase (who still has his Ambush Camo token active), do I need to specify the camo token that I am making regular?
I do not believe there is any basis for that Irregular orders are identifiable to a specific camouflage marker, and the command token use of converting it only affects the order not the trooper. You'd still have to keep track of which trooper it is and inform your opponent that the identity of the trooper the order belonged to is still private.
http://infinitythewiki.com/en/Irregular_Order My understanding is that you place the Irregular orders on the table (not on the order reserve per se), but you don't need to place that order next to the marker/model that owns it...
