    Dismiss Notice
Intelcom card
Discussion in 'ITS' started by DAE, Apr 11, 2018.
  1. DAE
    DAE Member
    Not quite understanding about the Intelcom card.
    When it says...
    "The content of the card, whether the mission or the card numeric value, is considered Private Information, no matter which use the player has chosen for it."
    Where is the numeric value...Bottom right?
    Doug
  2. Hecaton
    Yes. Ranges from 1-40.
  3. Robock
    Robock Well-Known Member
    yes.
  4. DAE
    DAE Member
    Okay. So then I take that the 40 is 40pts...added to say Support and Control option?
  5. xagroth
    On some ITS missions there is a paragraph with Intelcomm as the title and how to use that Intelcomm option. Generally, you either add that numeric value to the troop's cost when determining who has more points in a zone to see who controls it, or to remove an enemy specialist's category in scenarios in which one has to control a console or the like.
    For example, I have an 8 points remote (flash pulse, mimetism, basic remote) in a sector, but there is an enemy trooper (let's say a Fusilier from PanOceanĂ­a). You add the Intelcomm card (you decided to use the card as such at the beginning of the match) to your remote, let's say its a 40pts valued one (beware: the easier that is to do the secondary objective, the more points they add) and now the sector is yours (unless the enemy does the same thing, that is) because your 8 points remote is considered to cost 48 now.
  6. DAE
    DAE Member
    Thanks.
