Infinity Army 7 (N4) Updates & Bugs
  1. Danimoth
    Danimoth New Member
    Army: Combined Army & Onyx Contact Force
    Troop: Xeodron & Avatar
    All platforms
    Description of the bug: Staldron of Xeodrons and Avatar are lacking (Remote) skill.
  2. Ieldin Soecr
    Ieldin Soecr Well-Known Member
    Army: Ariadna, Caledonia, Merovingienne, Kosmoflot, Tartary, USAriadna, Dashat
    Troop: Traktor Mul
    Data Files
    Description of the bug: Traktor mules have one profile with the id 2, should be id 1.
  3. Durian Khaar
    Durian Khaar It's clubbering time...
    Army: Haqqislam
    Troop: Nasmat
    Firefox
    Description:
    Upon adding the Nasmat the error is displayed: Peripheral must be in the same group as doctor or engineer. However the Error Icon is not appearing.
    Lists are not legal if adding a Nasmat to Ghulam Doctor, Sekban Doctor, Rouhani, Asawira etc. So it has to be an error on the Servant side.
    @Koni Please fix Asap, as it keeps people from submitting their lists to tournaments. (PS: Koni, I know you are not the person to fix this, but you sit right next to them, at least in normal times :stuck_out_tongue_winking_eye:)
    Olkioum and Uthoroc like this.
  4. Psyence
    Psyence New Member
    Army: Haqqislam
    Troop: Muyib Spec-Op
    Platform: Android Army 7 app
    Description: Unit does not generate an order when added to list.
  5. Psyence
    Psyence New Member
    Army: All
    Troop: Any Spec-Ops
    Description: When generating a code to share a list containing a Spec-Ops troop, the application crashes.
  6. Moranic
    Moranic New Member
    • Army: N/A (mostly)
    • Troop: N/A
    • Browser used & Operative System: Appears to be any
    • Description of the bug: Not really a bug exactly, but an error: The Weapon Chart list in the app says the Flammenspeer has damage 14 in both modes, when it should have 15 in the hit mode, right?
  7. KGG
    KGG Well-Known Member
    Army: Nomads
    Troop: Interventor
    Platform: IPhone army 7 app
    Description: Interventor killer hacker not listed as (hacker)
  8. HellLois
    He should be on it.
    Myomer and Nuada Airgetlam like this.
  9. Triumph
    Is still not being able to print courtesy lists a bug at this point?
  10. Lawson
    Lawson Well-Known Member
    There have been a couple of questions previously about figures who have hacking devices but are not listed as Hackers (@RolandTHTG mentioned the ALEPH Apsara w/ Killer Hacking device way back in October and it still shows up without Hacker). I'm a bit unclear on whether it is conceivably possible for there to be a non-hacker with a hacking device (from a rules/balance standpoint to deny them specialist status or based on points cost or whatever) or if I should consider all figures who have [Killer] Hacking Devices but don't have the Hacker skill as a bug in the meantime. The other example I'm seeing is the O12 Betatroopers with KHD but not Hacker and @KGG just mentioned the one Interventor with a KHD as well. It seems specifically limited to KHDs.
    KGG, Hecaton and RolandTHTG like this.
  11. Hecaton
    Army: Combined Army
    Troop: Unidron Batroid, Umbra Legate
    Bug: SWC cost was removed from some of the K1 combi profiles, but not all.
  12. Hecaton
    Army: Ariadna, Kosmoflot
    Troop: Rokot
    Bug: Rifle + Light Shotgun Lieutenant profile costs 0 points.
  13. RobertShepherd
    Army: Combined Army / Morat Aggression Force
    Troop: Rasyat
    Platform: Windows / Chrome
    Description: Rasyat has both Courage and Religion Troop
  14. toadchild
    Rasyat and Kendrat both have this issue, and have since at least October (last time I did a bug roundup post)
    Edit: and the Taryot as well.
    RobertShepherd likes this.
  15. tox
    Optional skills
    Should be reported also in the Special Skill list in the printed list and not just in the title.
  16. HellLois
    FIX LIST 09/02/21
    Muyib Spec-Op now generate an order when added to list.
    Flammespeer Hit Mode changed damage value to 15.
    Umbra Samaritans: Added Stealth.
    Krakot: Fixed AVA on Ikari.
    Achilles V1: Deleted the Fireteam Duo.
    PSI-Cops: Added MULTI to the Marksman Rifle on the VM1 and Biometric Visor profile.
    Yan Huo: Fixed name mistake.
    Keisotsu: Fixed Fireteam Note.
    Spotlight: Added Non-Lethal Trait on the Hacker programs chart.
    Jaan Staar: Added Note.
    Uhlans: Deleted Peripheral on Crabbot.
    Rasyat: Added CC Weapon on the Specialist Operative profile. Deleted Courage.
    Taryot: Deleted Courage.
    Kendrat: Deleted Courage.
    Machinist: Fixed cost on SAA Machinist.
    Bolts: Added Fireteam Core and Duo on Foreing Company
    Brawlers: Fixed Fireteam options on Foreing Company.
    Deva Functionaries: Deleted Fireteam: Haris on NCA
    Samekh: Minor note edition
    Rokot: Lieutenant Rifle andLight Shotgun profile fixed cost
    Delta: Fixed double Light Riotstopper on hacker Profile, and the Double Parachutis on the Yodbot-B
    no missing ;)
    yep
    no bugs on those 3 ;)
    it change the MOV attribute, and gain +1 damage an now is veteran
    Yep
    its correct on the Army
    thats correct.
    purposeful omission
    #936 HellLois, Feb 9, 2021
  17. Triumph
    I'm assuming you're talking about Qiang Gao, he didn't gain +1 damage he already had Fatality lvl1 in N3. His points don't add up.
    When we break him down against the Zuyong he comes up like he's missing rules or stats. He went up in cost when other HI with more rules and guns on them went down in cost, he appears like he's paying at least 8pts for +1 ARM and +3 BTS. The Hac Tao lost 5 points and still received the movement stat change while Qiang Gao managed to increase in cost. Something is wrong with Qiang's profile.
    Forgive me for being skeptical but this seems alot like the time we were told the price on the Celestial Guards were correct, which wasn't the case they were being charged some N3 prices on things and they were quietly fixed after it was checked.
    #937 Triumph, Feb 9, 2021
  18. HellLois
    I understand you, but im only the messenger.
    I will never forget the Celestial Guards cost change....
    anyway....
    Fixed the error: Peripheral must be in the same group as doctor or engineer with the Skill Doctor with MODs.
  19. Triumph
    Well we tried I guess. I'll just have to wait until someone realises Gao's profile is N3 Krit Kokram levels of trash tier awful and fixes it so it's more like N4 Krit Kokram otherwise it's never going to get off my shelf and onto the table.
    Hecaton and HellLois like this.
  20. Reece
    Reece EI Aspect
    [delete me, I can't read good] ;)
    #940 Reece, Feb 9, 2021
    HellLois likes this.
