Infinity Army 7 (N4) Updates & Bugs
  1. JordanJoestar
    JordanJoestar Member
    • Army: Neoterran and Qapu Khalqi
    • Troop: All
    • Browser used & Operative System: iOS
    • Description of the bug: unit profiles and army lists do not load. Cannot access the filters or adjust points. It only does this with these two sectorials all the other ones load and work fine. Since they’re “new” additions I think it may be a more common bug.
  2. colbrook
    Mike has confirmed on FB this is being worked on, as a workaround we can go into play mode, change the positions around, and go back to build mode when done.
  3. archon
    I noticed the "turn to red" thing and see it as a feature to mark the units, that will break the point limit.
    I think (and just try out) it has no impact on LT profiles.
  4. Nuada Airgetlam
    The turn to red feature doesn't account for +1 SWC models like Neema.
    Also, it's a huge shame that right after the release of the missing sectorials N3 Army was taken down. We haven't been allowed to make comparisons like we could with the other armies :|
  5. Nuada Airgetlam
    Also, the bug I've previously reported still persists. Even if you set the validation to 300 pts, as soon as you click away and it goes to the C1 default of 30. And now it also turns the profiles RED, because they "don't fit" into your 30 pts army.
    Please fix :|
  6. Mahtamori
    Ah, got it to work.
    For me it doesn't seem to do anything with LTs at all, only (tries to) validates the SWC and points.
  7. cibili
    cibili Well-Known Member
    Army: QK
    Troop: Sekbans
    OS: IOS (IPhone)
    Error: Wildcard rule for Sekban is not shown
    Sent from my iPhone using Tapatalk
  8. DeusVult92
    DeusVult92 New Member
    Army: All
    Troops: All
    OS: IOS (iPhone Army App)
    Error: When you rotate or lock your iPad/iPhone the current displayed list is deleted.
  9. wes-o-matic
    wes-o-matic Meme List Addict
    Army: PanOceania, NCA
    Troops: Clausewitz Uhlans Crabbot Ancillary Remote Unit
    Browser: Safari desktop browser, AND iOS Army app
    Error: Troop profile displays the Peripheral icon but it should not
  10. Foxbringer
    Foxbringer Well-Known Member
    Army: NCA
    Troop: Machinists
    OS, Browser: Win 10, Firefox
    Error:
    In machinist comment: The NCA option can be part of any Fireteam of Neoterra Bolts.
    In bolts comment: The Machinist NCA can be part of any Fireteam:Core of Neoterra Bolts.
    Which one is true? (in charts only Core option)
    Would be strange if he is the only sectorial engi who can't join appropriate haris for some reason.
    #810 Foxbringer, Nov 20, 2020
  11. Foxbringer
    Army: Acontecimento and Haqqislam
    Troop: Machinists and Daylami
    Errors?:
    Machinist with mimetism and total terrain have the same cost as simple Machinist.
    Daylami(LSG, Pf) with camouflage and infiltration have the same cost as simple Daylami(LSG, Pf).
    Are this intended?
  12. danilapal
    danilapal Member
    Army: Pano, NCA, SWF
    Troop : Locust
    Android , Chrome, Mozila
    Error: Locust with submachine gun lost his Wild parrot.
    Or it is intended ?
  13. kesharq
    kesharq Lucky Dice-Roller
    Since Wednesday evening I am no longer able to start the App on my smartphone using Android 4.4.2
    Error Message: "Infinity Army angehalten"
    I deleted and reinstalled the App several times, but no change to that error. As Play Store is still showing the App for download, it might be a problem with my phone (If Android version would be the problem the App would not be shown).
  14. Nuada Airgetlam
    You're so many versions of the OS behind though. I know it's hard, but it's really obsolete by now and lack of compatibility of newer versions of apps is not surprising. Is there a way you could at least update the phone / tablet you use to 6? That ought to cover enough compatibility for most apps still in development.
    Zoe likes this.
  15. Sabin76
    Army: CA, Shas
    Troop: Shasvastii Spec Ops
    OS/Browser: MacOS/Chrome
    Error: The troop has "Immunity" with no designation afterwards. Should probably be "Immunity (Shock)" to be in line with regular Nox troops.
    Army: CA, Onyx
    Troop: Nexus Spec Ops
    Error: The troop has "Dodge" with no designation afterwards. Should probably be "Dodge (+3)" to be in line with regular Nexus troops.
    Dragonstriker and toadchild like this.
  16. Lawson
    Lawson Well-Known Member
    Whatever was happening before re: weapon range bands getting cut off is not longer happening for me, so it seems to have been resolved somehow.
    That said I'm noticing a new one:
    Burst values for Hacking Programs and Martial Arts, when they are added via the menu and shown in print/pdf view, appear as "lista.rafaga" rather than "Burst" or "B". See image attached:
    Zoe likes this.
  17. Knockout_013
    Knockout_013 Josh Tyth (QLD, AU)
    • Army: Spiral Corps
    • Troop: [SPEC OPS] Taagma Schemer
    • Browser used & Operative System: Win10, Chrome.
      Spec Ops' version of Taagma has "Immunity" (nothing) instead of Immunity Shock
  18. Nuada Airgetlam
    Same for Grunt Spec Ops.
    Knockout_013 likes this.
  19. Tourniquet
    Tourniquet TJC Tech Support
    Army: Steel Phalanx
    Troops: Throakitai, Myrmidons
    Broswer/OS: Firefox, Win10
    Description:
    Lost the Fireteam Enomotarchos rule meaning at worst as far as army is concerned they can no longer form fireteams and at best they require a hero to form that fireteam.
    Is this intentional?
    If so why walk back what was perceived as a very welcome Quality of life change to the army despite being a bug?
    xagroth, Hiereth, Iver and 1 other person like this.
  20. toadchild
    I believe the whole point of Enomotarchos is that you need at least one hero to lead the squad.
