Infinity Army 7 (N4) Bugs
  1. Iver
    Iver Human Plus
    Army: Aleph
    Unit: Apsara
    Device: All
    The Apsara's RemDriver profile costs 1 SWC in vanilla which it does not in the sectorial army. It carries no equipment or rule that should cost SWC.
    El tito Zylito likes this.
  2. KujakuDM
    KujakuDM Vigilo Confido
    Army: Ariadna (TAK)
    Unit: Colonel Voronin
    Device: Android
    Once in Play where you can click on skills to link to the Wiki, Voronin's Strategos L1 links to a blank page.
  3. Sense42
    Sense42 New Member
    • Army: Svalarheima's Winter Force
    • Troop:Jotums
    • Browser used & Operative System: Chrome, Win10
    • Description of the bug: The Crabbot is equipped with a "CC Weapon", not a PARA CC Weapon
  4. colbrook
    colbrook Black Fryer
    They had knives in N3, so I don't think that's a bug.
  5. Tourniquet
    Tourniquet TJC Tech Support
    Army: O-12
    Unit: Zeta
    Device: all
    Has ECM: Guided (-8), as it is not a multiple of 3 was this intended?
    Army: Corregidor
    Unit: Senor Massacre
    Device: all
    Appeared to have lost shock immunity in the edition change (was previously a part of Regeneration), was this intended?
  6. longshot
    longshot New Member
    Army: Haqqislam
    Unit: Nasmat remotes
    Device: All
    Nasmats have Peripheral (synchronized) and should have Peripheral (Servant)
  7. HellLois
    Fix List 27-10-2020
    Delta Yudbot: Added Parachutist
    Bit: Fixed the double Hacker
    Bulleteer: FIxed Fireteam in Varuna and White Company
    Nisse: FIxed Fireteam in White Company
    Dozer: Fixed Spelling error in engineers name
    Adill Mehmut: Added Dodge (+1”)
    Sargosh: Change in Martial Arts from N2 to N3
    Ectros: Changed MOV and added NCO
    Neema: Changed MOV and changed (+1 Command Token) on Lieutenant Spitfire profile
    Grunts: Added Note.
  8. fatherboxx
    but Tohaa is not even in the builder
  9. Nuada Airgetlam
    toadchild likes this.
  10. Mahtamori
    Let's see, still outstanding for Yu Jing is;
    • Army: ISS
    • Troop: Zhanying
    • Browser used & Operative System: All
    • Description: AVA is 2 (vanilla), should be 4
    • Army: ISS
    • Troop: Yudbots
    • Description: AVA is 4, should be 2
    • Army: Yu jing & IA & WB
    • Troop: Qiang Gao
    • Description: Seems to have had HI discount added instead of removed to total. Or is missing skills?
    • Army: Yu jing & ISS
    • Troop: Sun Tze v1
    • Description: Seems to have missed getting the hackable discount; other Total Immunity units got cheaper (even the unhackable ones), other Strategos HI got discount.
    Edit, forgot this one:
    • Army: All
    • Troop: Guided Missile Launcher Remotes
    • Description: Even though they all have the same stats, weapons and abilities, they have different prices.
    Edit, more things:
    • Army: Yu Jing & IA
    • Troop: Yan Huo
    • Description: Lieutenant profile still missing FTO notation (important for hiding LT and for getting the damned thing into a fireteam)
    • Troop: Yan Huo Neurocinetics
    • Description: I think that technically this bonus still doesn't work because it is a burst bonus, or it works because it is a burst bonus in square brackets but it will work in the active turn as well.
    #690 Mahtamori, Oct 28, 2020
    Dragonstriker and toadchild like this.
  11. Durik
    Durik Well-Known Member
    I duplicate the problem still written on October 7, 21 days have passed, please fix it
    Aelis still has a problem with the wild card.
  12. toadchild
    I’ve been meaning to do a validation pass over the issues in this thread to check for ones that are still unresolved, but have not had the time. Thanks for covering YJ!
    Dragonstriker likes this.
  13. Charbe86
    Charbe86 Member
    • Army:Aleph
    • Troop:Deva
    • Browser used & Operative System:Army app, android
    • Description of the bug: Deva lt with triangulated fire no longer has sensor
    • Army:Aleph, all?
    • Troop: N/A
    • Browser used & Operative System: Chrome and windows 10
    • Description of the bug: when printing a list, in the hacking programs under targets HI is being replaced with IP
    • Army:all
    • Troop:N/A
    • Browser used & Operative System:chrome and Windows 10
    • Description of the bug: when printing an army list the movement values of troops in the left column ar in inches, while the movement values of troops in the right column are in centimetres
  14. meikyoushisui
    Realistically, what do you expect players will be doing with the 2 Lieutenant orders on an unlinked Neema with a Breaker Combi Rifle?
    I feel like if anything, the Spitfire should have the Lt Order since it can actually function somewhat solo, and the Breaker Combi should have the Command Token because it won't be used as aggressively...
  15. Teslarod
    Offtopic, but given Hellois accidentially revealed Ectros NCO... that. Neema provides Lt Orders Ectros uses them in the same Triad.
    Incentive to run some HI in Tohaa for Order efficiency beyond 6-2.
  16. Delta57Dash
    Delta57Dash Well-Known Member
    Just to add to the list of outstanding issues, but the Tikbalang is still dodging on 15’s...
    Teslarod likes this.
  17. Teslarod
    If it doesn't get fixed, I'll gladly take it as intended ;D
    Confirmation or a fix would both be nice.
  18. Icchan
    Icchan Well-Known Member
    • Army: Haqqislam & Hassasin Bahram
    • Troop: Daylami
    • Description of the bug: Daylami Light Shotgun, Panzerfaust profile with and without infiltration and limited use camo cost the same, despite the other having extra skills.
  19. WiT?
    WiT? Well-Known Member
    CB adds order efficiency to tohaa, tohaa players bitch and it gets taken away. All is as expected.
  20. meikyoushisui
    I will still take the Lt order over nothing, obviously, but since Spiral Corps is a supported army and Tohaa is not, I am more concerned with how pieces fit together in Spiral Corps.
