Infinity Army 7 (N4) Updates & Bugs
  1. tox
    Can we have back the Discover ranges in the weapon table?
    Daniel Darko, Hiereth and Reece like this.
  2. Iver
    Iver Human Plus
    As well as suppressive fire ranges
    (also, I felt the things I reported about the Apsara and Hippolyta was overlooked again)
    Terrenor likes this.
  3. archon
    Same Problem here.
  4. eganra
    eganra New Member
    • Army: Ariadna / TAK
    • Troop: Scout
    • Browser used & Operative System: win10 /chrome
    • Description of the bug: Minelayer profile changed to shock mines instead of EM mines
  5. schlaf
    schlaf New Member
    so, is this a bug? i think yes. if you "sort" a list, and the "displayed" list is not consistent with the sorting. at least the entries of the list should display the criterion of which it is sorted, or make sure the "ISC" and "name" are consistent for at least 3 or 4 first characters (obviously, you sort by "name", who in the world will search for the croc men at P ?)
    also, sorting on the "army id" is probably totally useless, as you can not even KNOW the id of the troop (it is not displayed, either in list or in the detail window)
    last one, sorting on "category" is also not really usefull (category is not displayed in the list) and inconsistant, as "veteran troops" is ordered before "elite troops" for example, and there are other ordering problems on this criterion like characters at the end before mercenaries (at least for panoc army).
  6. Stiopa
    Stiopa Trust The Fuckhead
    Faction: Ariadna
    Unit: Traktor MULs
    System: Chrome/Win7
    Issue: Spelling error in engineers name, "Dozers" instead of "Dozer"
    Thank you. Would it also be possible to add a "Kuryer Controller"/"Traktor Controller notes to their respective Dozers? It makes it easier to see them in a list
  7. multor
    multor Member
    Faction: All
    Unit: All
    System: Win10/Firefox/Opera
    Issue: (not urgent, it´s a comfort feature, not a bug): The range modifiers on black&white printed lists are hardly readable.
    Is it possible to bring back the optional printer-friendly black & white range bands, please?
    Thank you for your awesome work!
    Maniac-Eye, Zoe and RolandTHTG like this.
  8. toadchild
    Army: Combined
    Troop: Bit & Kiss
    Platform: Windows Chrome
    Issue: Bit's profile line says "Hacker" twice.
  9. Vanderbane
    Vanderbane Well-Known Member
    I've seen it proposed the above is intended as an omission in O-12 vanilla (same with Knights of Santiago & Tian Gou), but have not seen official word. Is this an intended omission in all three cases?
  10. colbrook
    On the other hand he's available to O12 in Code One.
    Reece, paraelix and Vanderbane like this.
  11. Azza
    Azza New Member
    Just out of curiosity.. In the new edition when remotes can be taken without hackers why do traktor muls still need a dozer, especially when hungries lost the control device?
    Also under traktor muls and Kuryer they both have and now specify you need a dozer to run them, they don't specify you have to choose a certain one, just have a dozer.. Ie if you choose normal dozer then you can't run any muls or kuryer as army gives you a cross for not having a controller, there's nothing stating what one is a controller you just have to assume its the ones with notes under the mul and Kuryer, and those notes don't mention it's a controller, it merely mentions to take a dozer ie comes across as any dozer..
    If you take the dozer under muls you can't take Kuryer also unless you take a dozer from under Kuryer yet there is nothing that seperates or distinguishes each dozer from each other or who is in control of what unless you are looking and building ie select the correct one under.
    Also kuang shi only ask that you take celestial guard liason profile to run them, but only the liason under the kuang shi work, not the liason under celestial guard profile, that gives you a cross.. Yet it's only a note that seperates the two yet the note only specifies take a liason to which the one under celestial guard section is one.
    Panzerschwein likes this.
  12. Phayton
    Phayton Well-Known Member
    • Army: NA2 / White Company & Druze Bayram Security
    • Troop: Bulleteer
    • Browserused & Operative System: win10 /chrome
    • Descriptionof the bug: Profile has Fireteam: Duo but it is not listed in the sectorial charts
  13. paraelix
    paraelix Seed Embryo Scholar
    Existing fluff descriptions for both Sphinx and Cutter - both are outfitted with advanced optical, auditory, and electrical masking tech.
    Background
    The Special Armored Corps is a non-conventional penetration unit according to Shasvastii tactical philosophy. Its Sphinx units (a human designation code) can work as an attack vector for the Expeditionary Forces, making the best use of their high speed and stealth abilities. However, they can also be used as an armored reconnaissance force in maximum hostility environments.
    To carry out these combat functions, the Sphinxes have been equipped with advanced concealment and invisibility systems that allow them to avoid security and sensor networks. With the purpose of improving their operative performance capacity, they have been fitted with silent mobility equipment, as well as active noise cancellation and electromagnetic masking. Their armored shell has a surface of non-magnetic and non-conductive composite polymers. This surface has properties of light emission that allow it to project camouflage, thermal patterns, and directional polarized holograms. They also have a specialized semi-intelligent computer that deals only with the control of these Thermo-Optical Camouflage Systems, using the information provided by external sensors to optimize the camouflage. In addition, their special mobility mechanisms allow them to move silently, but at maximum speed, over any plane or surface of the battlefield.
    The Sphinxes are specialized in covert operations, in which stealth becomes their most powerful weapon. They are big, invisible war machines that move in silent synchrony with the environment until the time comes to display all their armored power in the middle of the enemy lines, where the most damage can be done.
    Background
    “Nemo nos effugit” (Nobody escapes from us), motto of the Naval Chasseurs Regiment.
    The Cutter is the Remote Presence armored gear model used by the Varuna Chasseurs Regiment of the Rapid Intervention Division. It was conceived for undercover operations and amphibious or underwater operations. Its design includes sound-suppressing equipment and an environment-adaptive skin capable of changing its reflective, radiative and electrical properties at will, effectively canceling its optical and thermal output. In the interest of maneuverability and stealth, its principal design requirements, it has foregone the use of a secondary weapon. Cutter units are also used by the armored division of the “Blue Sea” anti-terrorism project. They are responsible for undercover insertions in highly volatile areas, but their operational remit also includes punitive actions and control of operational perimeters to avoid target withdrawal.
  14. WiT?
    WiT? Well-Known Member
    • Army: Hassassin Bahram
    • Troop: Rafiq
    • Browserused & Operative System: chrome, windows 10
  15. 1337Bolshevik
    Army: Kosmoflot and Ariadna
    TRoop: Kosmosoldat
    Issue: Is he supposed to have +1 Damage on the AP hmg profile rather than +1B? In the spoiler he had +1B.
    Stampysaur and Panzerschwein like this.
  16. QueensGambit
    Army: Hassassins (but probably all)
    Troop: All
    Issue: Lists saved to Server overwrite each other in unexpected ways.
    It seems that when I edit a list, it considers it to be the "same" list for saving purposes even if I change the name. This leads to unexpected overwrites. For example:
    I make a list, name it "List A," and save it to the server.
    I make some changes to it, name it "List B," and try to save it. It asks if I want to overwrite the existing list, and I have to say "no" (which is counterintuitive).
    Later, I load List A from the server, make some changes, and try to save it as List A again. It asks if I want to overwrite the existing list, and I say "yes" because this is a change to list A. However, the result is that it overwrites List B instead of (or maybe as well as) List A.
  17. Spleen
    Spleen Well-Known Member
    • Army: White Company
    • Troop: Nisse
    • Browser used & Operative System: Chrome - Windows 10
    • Description of the bug: Nisse are listed as having Fireteam Haris in the White Company sectorial, but are not listed on the sectorial chart as capable of forming any Fireteams. Contrary to this, Karhu have Haris natively in their home sectorial of Svalarheima like the Nisse, are not listed on the sectorial chart as able to form Haris, and DO NOT have Haris in Army under White Company. I believe there is an error either within Army or the Sectorial Chart.
  18. Azza
    Azza New Member
    Ariadna HI minus the blackjack are the only HI in army that don't have hackable symbol.
    No-hackable skill exists in N4 rules and they were non hackable in n3, are they supposed to have the non-hackable skill in army but its missing?
  19. Iver
    Iver Human Plus
    Army: PanOceania/Military Orders
    Troop: Tikbalang
    browser: Windows
    Description: TAGs usually have a dodge value separate from their Physicality value. The Tikbalang does not and thus dodges on full 15's. Intentional? If so, it's a very graceful giant robot.
  20. Binary Ballerina
    Binary Ballerina New Member
    Army: Shasvastii / Combined Army
    Troop: Sargosh
    Browser used & Operative System: Edge / Windwos 10
    Description of the bug: Sargosh has a Light Shotgun, although the model seems to be equipped with a light flamethrower. He also has the light flamethrower in Code One. Is this change intentional?
