Infinity Army 7 (N4) Updates & Bugs
Tema en 'Infinity Army' iniciado por Koni, 25 Sep 2020.
Estado del tema:
  1. geckoguy
    geckoguy Member
    19 Oct 2018
    This has been confirmed as intentional by ijw on pg. 6 of this thread, i think
    A Nimlothautle le gusta esto.
  2. natetehaggresar
    27 Nov 2017
    Army : Starmada
    Troop : Alpha
    Browser : Andriod Army App
    Description : Alpha is included as a unit choice. The sectorial army chart PDF omits Alphas. Is Starmada supposed to have access to Alphas?
  3. ldgif
    ldgif Well-Known Member
    4 Ene 2018
    @ijw Is the Long Ya suppose to be missing Mimetism now?
  4. Arkaon1125
    Arkaon1125 Well-Known Member
    13 Abr 2018
    • Army: Pan-o
    • Troop: Trinitarian Tertiaries
    • Browser: Infinity Army 7, as well as Android
    • Description: Trinitarian with minelayer does not sum up it's order to the total
  5. WiT?
    WiT? Well-Known Member
    28 Dic 2017
    • Army: TAK
    • Troop: Strelok w/ Antipode
    • Browser used & Operative System: Chrome & Windows
    • Description of the bug: Lots of the Antipode abilities do not show up on printed army list ie Trench Hammer or "Dodge +2"
    • Description of the other bug: Flash Pulse and Discover not in weapon chart.
    #225 WiT?, 28 Sep 2020
    Última edición: 28 Sep 2020
  6. Terrenor
    Terrenor Active Member
    2 Ene 2019
    • Army: Nomads Corregidor
    • Troop:senior massacre
    • Description: In the wildcard Text FTO is mentioned there is no FTO Profil
    Adjuntos:
  7. Terrenor
    2 Ene 2019
    • Troop:Jazz and Billi
    • Description: Is it right that the FTO profil although gets Billi?
    Adjuntos:
  8. Jenian Katarn
    Jenian Katarn G:Synchronized
    8 Ene 2019
    • Army: JSA (Assumed happens on others too)
    • Troop: Shikami, Tanko, Domaru (I assume this happens with all)
    • Browser: Firefox, Windows 10; Firefox Linux Mint 20
    • Description: When trying to print army-list, the list pops up on new browser window with dialog for printing (as I assume should happen). However, when I click print in the printer dialog that opens up with the preview window (choosing either real or pdf printer), the instance which provides the army-list window concludes and cancels the print procedure as well as closes the preview window. When doing this for pdf, the pdf file doesn't save as the dialog for the saving dies with the process also. However when printing through an actual printer, the paper print does print.
      Other details:
      - Print preview window is not interactable when the printer dialog is open.
      - I was not able to reproduce this on Brave-browser; on Brave the preview window stays open until I close it after printing.
    • Army: JSA (Assumed happens on others to too)
    • Description: When generating a link to your list to be pasted somewhere, the name of your list doesn't appear when following said link. It shows a single white space on otherwise blank field (even those brackets that show normally are missing).
    • Army: -
    • Troop: -
    • Browser: Firefox, Linux Mint 20
    • Description: Not a bug but UX/UI -feature. When opening the link for Infinity Army webapp and army opens showing the main page where the choise for using Infinity N4 or CodeOne army comes, it isn't apparent that you have a choise to make. On quick glance it looks like you have chosen CodeOne army as the side by side view of "Infinity" and "CodeOne" fools your brain to think that this is "Infinity CodeOne" army you've opened. I'd recommend adding some kind of separator between the options.
      EDIT: Added following:
    • Army: -
    • Troop: -
    • Description: Optional list (previously known as Courtesy List) is with the private information hidden is not available anymore. This isn't a thing in the rules but if the courtesy lists are a future ITS feature, then it would be nice to have that option.
    #228 Jenian Katarn, 28 Sep 2020
  9. Tongfa
    Tongfa ULTRA INSTINCT UKR
    6 May 2018
    Assume its a bug, but in the Varuna builder, Multi HMGs Weapons profile have things like the EXP being full burst of 4 instead of 1.
    Didn't have a look at other armies/weapons profile, but assume it's an issue with other Multi weapons as well (i.e. DA snipers, etc).
  10. MicroWarp
    MicroWarp Well-Known Member
    6 May 2018
    Army:- Varuna
    Troop:- Richard Quinn
    Browser:- iOS
    Description:- Possible error but could just be a change. Richard Quinn missing from Varuna (in N4). I’ve just had him painted up too!
  11. Foxbringer
    Foxbringer Well-Known Member
    5 Feb 2018
    Army: MO
    Troop: Magister, Teuton, Mobility Joan, Montesa and Seraph
    Browser & OS: Firefox, Win 10
    Description: They don't have stealth.
    Hope, this one is not a feature.(I believe it's ok for seraph and mounted montesa not to have it, but JSA tag and motorbike have, so...)
  12. Terrenor
    2 Ene 2019
    NewArmy: Ramah Taskforce
    Troop: Khawarij
    Browser & OS: Android Army App
    Description: I'm missing the sentence that Khawarij counts as Ghulams for fireteam.
    Adjuntos:
  13. ijw
    25 Abr 2017
    As per the blog post about Army, courtesy lists will be added again at a later date.
    Known bug!
    This is a feature.
    By the way, if you look at Yojimbo, he only has Stealth in his Dismounted profile.
    A Foxbringer y Jenian Katarn les gusta esto.
  14. tox
    21 Feb 2017
    Is there a way to order the unit entries? They are also different from APP and web.
    Moreover, dropbox for skills and equipment are not in alphabetical order. Weapons are already.
  15. Mahtamori
    Is it safe to assume that all units that in N3 had Stealth but are listed without it are intentional changes? E.g. Shikami etc
  16. ijw
    25 Abr 2017
    In the web version, open up the OPTIONS tab and there's a Unit Sorting section, like in Army 6.
    Shikami and Daiyokai are typos (I forgot to post that, as it was late), but for other factions, yes.
  17. emperorsaistone
    30 Nov 2017
    • Army: Haqqislam and Ramah Taskforce
    • Troop: Khawarij and Tarik Mansuri
    • Browser used & Operative System: Windows 10 / Firefox
    • Description of the bug: Tarik is missing Terrain(Desert) which the Khawarij have. Khawarij might also be missing Stealth, which Tarik has.
  18. SpokeyDokey
    SpokeyDokey New Member
    6 May 2018
    Army: Aleph/Operations
    Troop: Samekh Rebot
    Browser/OS: Firefox
    Description: Samekh profile block is identical to n3 version. Smart missile launcher does not exist and the remote did not get the same 1/2 point discount as the equivalent in other factions
  19. Iver
    Iver Human Plus
    3 Feb 2018
    Army: ALEPH/OSS
    Troop: Ajurna
    Browser/OS: Android
    Description: One of the profiles does not grant an order.
    Army: ALEPH/OSS
    Troop: Asura
    Browser/OS: Android
    Description: The SWC of her non-lieutenant hacker option is wrong.(I assume, looking at the lieutenant option. Should be 0.5, not 1.5)
  20. tox
    21 Feb 2017
    Army: CA (and sectorials)
    Troop: all the TAGs
    Browser: app and Chrome (pc)
    Description: ECM missing any modifier
Estado del tema:
