Hey! As I am looking into it: Impersonation skill has NFB label, but Impersonation State does not. I am reading it wrong? As current rules allows that the Troopers that is hiding under it, that also have Mimetism(-3/-6) (so most of KHD Infiltrators) will benefit from both, and it will be harder for their enemies to Discover them?
States don't have that kind of label, the states' governing skills do. Cybermask says that the skill's effects lasts until the IMP-2 state is removed and there's a yellow "REMEMBER" box under the skill in the rulebook that reminds you that you can't be bother IMP-2 and Camouflaged at the same time due to NFB
Ok, I do understand that I can't be under Camouflaged state and Imp-2 State at the same time, the same logic can be applied to Imp-2 State trooper with Mimetism special skill, right?
If you've got an NFB skill running that states it lasts until you leave IMP-2 state, can you activate another skill with NFB without first cancelling IMP-2 to cancel the NFB skill you have running that allows you to be in IMP-2 state?
