How does Coordinated AD work with ITS 10 changes?
Discussion in '[Archived]: N3 Rules' started by Tom McTrouble, Sep 4, 2018.
  1. Tom McTrouble
    Do all troops using combat jump still have to fit inside a single template?
  2. dlfleetw
    dlfleetw Well-Known Member
    BtB contact only!
    Real answer: Assuming no change to that portion of the rules was made by the ITS season modification.
    Tom McTrouble likes this.
  3. Robock
    Robock Well-Known Member
    either that or : all within a single template but now you don't need to make the template fit anywhere, so have one land on the roof and the other on the ground; or have two of them land on both side of the wall.
  4. Tom McTrouble
    This is probably how I would play it but RAW I think @dlfleetw is right.
  5. emperorsaistone
    I'd argue that there is no Drop Zone anymore, since the template represents the Drop Zone and therefore you can deploy them anywhere.
  6. cazboab
    Or on the other side of it, the drop zone is now the base meaning that you just can't land multiple troopers...
  7. ijw
    Indeed. There's no Drop Zone any more, but the Coordinated Order requirement of placing them all in the same Drop Zone hasn't been lifted. I can't see any way to argue for Coordinated Combat Jump in ITS10. Not that it was used very often due to the appalling Order inefficiency...
    Cartographer and paraelix like this.
  8. Tom McTrouble
    The rules forum has never been about what's an efficient use of orders and you know it.
    Teslarod, Robock, xagroth and 3 others like this.
  9. inane.imp
    A large proportion of the time it's not even about interactions that are at all practical in most games.
    Teslarod, ijw, xagroth and 2 others like this.
  10. Robock
    If there is no such thing as a defined "drop zone" game term, then drop zone must simply refer to its common word usage meaning the whole board since that is where you are dropping your miniature...
  11. xagroth
    There is no formal list of tags in this game, aside from the list of troops with the TAG cathegory XD
    cazboab likes this.
  12. Robock
    Jokes aside, Landing Assistance says
    "will not need to place the Circular Template to represent the Drop Zone"
    Not need does not equal must not and also
    "They can instead"
    Which is not the same as They must instead.
    And finally, this permission (to deploy on any flat surface) does not remove the permission the ruleset already gave you to use a Circular Template.
    You can opt to not use the landing assistance. Or at least you can opt to not use the replacement first paragraph but i think the second paragraph will still apply (cannot deploy inside a building that has a roof). As the second paragraph adds new restrictions to what the permissive ruleset already set in place without any option to ignore it.
  13. inane.imp
    Basically: you can still use a Template for a Zone and must if you want to Co-ord AD.
    Right?
    ijw likes this.
  14. ijw
    Yes, because the Combat Jump rules define the template area as the Drop Zone. No template, no Drop Zone.
