Hi. Holoecho says you can place up to three echoes on the table. Is that three including the main projector unit or three additional echos plus the main projection unit making it four all up on the table ? Also if using it to make an opponent waste orders. Do you let them move and shoot and not do anything and remove one echo off the table if that was not the main one and let them keep guess now with the last two ? thanks.
One of the echoes is hiding the real trooper. If an echo has a cancellation condition met, you remove that echo. If that is the real trooper, you remove all echoes. Cancellation conditions include, but are not limited to, being successfully hit, being successfully discovered, or the main trooper essentially doing any thing that's not a movement skill. Getting your opponent to effectively waste orders on a Holoecho is actually quite difficult. Primarily because your opponent is an intelligent being who probably knows you and can figure out when you're trying to pull a quick one on them.
