Can a trooper in HD declare cautious movement, if his hidden location is inside the enemys LoF or ZoC? (The end if the movement is outside) I think yes, because at the declaration of the order he is tecnecaly outside the LoF or Zoc, because he 'is considered not on the table' On the other hand, HD says:'when declaring an order...place a Camo marker at the location of HD
Hidden deployment trooper can’t ARO against (successful) cautious move. Unsuccessful cautious move (example: trooper accidentally ends its move in non-hidden enemy trooper LoF) provokes an ARO from Hidden deployment trooper Not 100% sure if a deployed equipment counts as a trooper in this case. Example can a camo mine or non-camo mine prevent hidden deployment in their ZoC?
No, you can’t. As you say, the marker is placed on the table when declaring the Order. The OP is talking about the Active Trooper starting in Hidden Deployment.
Ah, my bad. Read it incorrectly. You can’t bypass cautious move requirements by starting the order in HD.
