    Dismiss Notice
Help with my fav units
Discussion in 'PanOceania' started by Ayuruk, Apr 24, 2019.
  1. Ayuruk
    Ayuruk New Member
    Hi all. I'm still pretty new to the game and I'm having trouble building a list that uses me 3 favorite units (jeanne, seraph , and hospitaller)
    have it still be good. Can anyone look this list over for me and give me some feedback on it. Screenshot_20190423-183004_Infinity Army Mobile.jpg
  2. barakiel
    If you're going this route, I'd keep the HMG on the Seraph, grab an HMG hospitaller for the link, use mobility Joan for her Spitfire, then grab some a Hospitaller Doc with MULTI Rifle and then boarding shotgun Hospitallers to finish up the link. I think that gives you a really nice array of firepower across multiple rangebands.
    I take it you're not playing missions where you need to interact with consoles or anything?
    Ayuruk likes this.
  3. Ayuruk
    Ayuruk New Member
    Haven't played that yet. Really just have been playing general killing missions
  4. Stiopa
    Stiopa Trust The Fuckhead
    I'd say that taking Seraph, Joan, and any kind of HI link is a tough task. I'd rather go this way:
    Military Orders
    [​IMG]9 [​IMG]1
    SERAPH HMG, 2 Nanopulsers / EXP CCW. (2 | 79)
    [​IMG] CRABBOT Flash Pulse / Knife. ()
    JOAN OF ARC Lieutenant MULTI Rifle, Nanopulser / Pistol, DA CCW. (+1 | 50)
    KNIGHT HOSPITALLER HMG / Pistol, DA CCW. (2 | 39)
    FATHER-KNIGHT Missile Launcher / Breaker Pistol, DA CCW. (1.5 | 49)
    ORDER SERGEANT Heavy Rocket Launcher / Assault Pistol, Knife. (1.5 | 15)
    ORDER SERGEANT Paramedic (MediKit) Combi Rifle / Pistol, Knife. (0 | 15)
    ORDER SERGEANT Combi Rifle / Pistol, Knife. (0 | 13)
    MACHINIST (Father-Engineer) Combi Rifle, D-Charges / Pistol, Knife. (0 | 15)
    PALBOT Electric Pulse. (0 | 3)
    7 SWC | 299 Points
    Joan, Seraph and Hospitaller can use Joan's special Coordinated Order to maneuver into position. OS/FK Core works good both in offense and defence, just remember to dictate the range of engagement to favor you. Machinist is crucial for keeping the TAG running. But I won't lie that this kinds of lists are fragile, with obvious Lt and no CoC.
    Ayuruk and Golem2God like this.
  5. WiT?
    WiT? Well-Known Member
    A mate of mine has gotten good mileage out of Seraph and Joan, and argues that Military Orders isn't necessarily the best home for either.
    In vanilla, you can pair cheap irregular models with Joan to recoup some of the points you would otherwise spend on mediocre Order Sergeants. That means less cheerleaders and more ass kicking primary models. You lose the OS link options and the FK Missile posted above, which has some game, but get more active turn units
    Something like this jumps to mind;
    PanOceania
    [​IMG]3 [​IMG]4
    HELOT MILITIAMAN Submachine Gun, Light Rocket Launcher / Pistol, Knife. (0.5 | 9)
    MONSTRUCKER Submachine Gun, Chain Rifle, Drop Bears / Pistol, Knife. (0 | 13)
    WARCOR (Sixth Sense L1) Flash Pulse / Stun Pistol, Knife. (0 | 3)
    4.5 SWC | 198 Points
    Thats 7 orders, including Joan, Hospitaller, and HMG Seraph (you want the non-Auxbot version because G: Synch models cannot use Joan's coordinated orders) and 102 points for 3 last slots. With that you can fit a really strong model such as a Swiss Guard + two chumps, or two strong models such as other knights and a basic dude.
  6. Nomadimp
    Nomadimp Well-Known Member
    I'll second Barakiel's suggestions as a good place to start. I think as you play more, depending on your opponents, you'll eventually want to swap one of your hospitallers for a santiago KHD (easily proxied with a hospitaller for now) and figure out a way to get a machinist with a palbot in there.
    The machinist will help fix up your seraph if it gets damaged (or your HI if they get immobilized) and the santiago KHD will help defend against enemy hackers (or act as a specialist when you start doing missions).
    If you could tell us what tends to 'go wrong' when playing with your list that would be helpful as well. What are your opponents doing that you're having trouble dealing with? E.g. do they have lots of camo or hackers? Are you running into a linked missile launcher that is eating your lunch? etc. etc.
    Military Orders
    [​IMG]9 [​IMG]1
    KNIGHT HOSPITALLER Doctor (Fireteam: Haris, MediKit) Combi Rifle / Pistol, DA CCW. (0.5 | 36)
    KNIGHT HOSPITALLER Boarding Shotgun / Pistol, DA CCW. (0 | 31)
    6 SWC | 299 Points
    #6 Nomadimp, Apr 24, 2019
    Sungwon and Ayuruk like this.
  7. Section9
    Agreed, that's a LOT of points in 6 models.
    Military Orders
    [​IMG]6
    KNIGHT OF SANTIAGO Hacker (Killer Hacking Device) Combi Rifle, Nanopulser, D-Charges + 1 TinBot A (Deflector L1) / Pistol, DA CCW. (0 | 38)
    KNIGHT HOSPITALLER Doctor (MediKit) Combi Rifle / Pistol, DA CCW. (0 | 35)
    4 SWC | 272 Points
    You have 28pts remaining, and that's just not enough to cover your basic specialists. Hacker and Engineer and FO.
    I'd probably recommend dropping the Core team down to 3 (and running Joan separately, stupid Crusade Fireteam rules). I'd drop the shotgun, I think, to keep the Santiago KHD Tinbot in the link. Something like this, maybe:
    Military Orders
    [​IMG]8 [​IMG]1
    PATHFINDER DRONBOT Combi Rifle, Sniffer / Electric Pulse. (0 | 16)
    SPEC. SERGEANT Hacker (Hacking Device) Combi Rifle / Pistol, Knife. (0.5 | 21)
    4.5 SWC | 298 Points
  8. eciu
    eciu Easter worshiper
    What the point of not using full 5 man link ?o0
    mrstream and Stiopa like this.
  9. Section9
    While I normally agree, the full 5-man link and a TAG is just too many points in MO.
    AdmiralJCJF likes this.
  10. Spinnaker
    Spinnaker Vanguard Officer
    What are your thoughts on running the Sepulchre knight with chain of command and spitfire instead of the Hospitaller? It's a chunk more expensive, but it's a specialist, gains access to surprise shot, can mitigate assassinations attempts on Joan somewhat (although when you're making use of her Inspiring leadership with irregular troops, this is still an issue), and can make use of the suppressive fire + holoecho combo
  11. WiT?
    I only inc. the Hospitaller because OP said that was one of his favourite models, and don't usually run it outside of links.
    I actually really like the Sepulchre either in CoC or in FD modes. I really like any combat specialist, and the CoC Spitfire ticks that box - the other effects are just gravy. I also like heavy combat units with efficient means of deployment such as Forward Deployment L2.
    Spinnaker likes this.
  12. Ben Kenobi
    Ben Kenobi Well-Known Member
    Came up with the following list. It has only two Spearheads but you have a full core and a TAG
    Military Orders
    [​IMG]8 [​IMG]2
    4.5 SWC | 300 Points
  13. eciu
    You have to leave DZ ?
    Teslarod likes this.
  14. Section9
    Well, someone does, just to get to the objectives.
  15. Maksimas
    Maksimas Maxi
    Military Orders. Joan. Hospitallers. And a Seraph.
    I think I can dredge up some ideas...
    For the record, as an insane heavy infantry zealot as I am, I genuinely can see no method of fitting in Joan, her Hospitaller Fireteam AND a Seraph into one list without having taken a metaphorical Hac Tao HMG to your lone Keisotsu.
    The main issue in here stems from the Hospitallers, oddly enough. Joan and the Seraph can get along nicely, but the Hospitallers eat points like a Swiss Guard eats TR REMs in this trio.
    Though that doesn't mean limited Hospitaller amounts cannot be used instead, to shave some points.
    Military Orders
    [​IMG]9 [​IMG]1
    JOAN OF ARC Lieutenant MULTI Rifle, Nanopulser / Pistol, AP CCW. (+1 | 49)
    5 SWC | 300 Points
    Military Orders
    [​IMG]10
    KNIGHT HOSPITALLER Doctor (MediKit) MULTI Rifle / Pistol, DA CCW. (0 | 39)
    ORDER SERGEANT MULTI Sniper Rifle / Pistol, Knife. (1.5 | 21)
    SPEC. SERGEANT (CH: TO Camouflage, Infiltration, Forward Observer) Combi Rifle, Antipersonnel Mines / Pistol, Knife. (0 | 27)
    6.5 SWC | 298 Points
    Military Orders
    [​IMG]10
    JOAN OF ARC Spitfire, Nanopulser / Pistol, EXP CCW. (2 | 53)
    FATHER-KNIGHT Lieutenant (Forward Observer) Combi Rifle / Breaker Pistol, DA CCW. (0 | 45)
    5.5 SWC | 299 Points
    This is the best I can think of on short notice.
  16. Mikes
    Mikes Well-Known Member
    Joan is almost TAG on her own. I've run her and a seraph several times to some sucess, but the hospitallera in the aMe list can be an issue. The problem is their frenzy. They cost a lot of points so you want to recoul that by having them hurt things, but as soon as rhey do they become impetuous and lose their cover bonuses.
    Iwhile im a big proponant of take what you think is cool, in this case I'd suggest building teo lists, one for joan and the seraph and one with joan and hospitallers, and aim towards both of them.
    Infinity is a fun game, in or lose, but if you're just starting off there's little point in playing with the breaks on.
  17. Stiopa
    Frenzy won't activate as long as they're linked, so it's only the single Docs that need to be wary of this. Frenzy also kicks in only at the beginning of the next turn, so there's some time to still take advantage of cover, eliminate immediate threats and position your unit in a good spot. Additionally, units like that are best used as a backup fighters, not primary ones, and tend to get activated later in the game. If your knight kills someone on Turn 3, he won't lose the bonus before game ends, anyway.
  18. Hexa
    Hexa TAG pilot
    I think mixed PanO is a better place for both the Seraph and Joan, since they won't be receiving as much support from a link as they will from mixed units such as a monstrucker, a helot, a cobra jammer and krakots. I frequently play both in vanilla, but have never played MO.
    I'd consider playing something like this:
    A: Superior firepower──────────────────────────────────────────────────[​IMG]6 [​IMG]4 [​IMG]1 SERAPH HMG, 2 Nanopulsers / EXP CCW. (2 | 79) [​IMG] CRABBOT Flash Pulse / Knife. () JOAN OF ARC Lieutenant MULTI Rifle, Nanopulser / Pistol, DA CCW. (+1 | 50) KNIGHT HOSPITALLER Doctor (MediKit) MULTI Rifle / Pistol, DA CCW. (0 | 39) KNIGHT OF SANTIAGO (Specialist Operative) Spitfire, Nanopulser, E/M Grenades, D-Charges / Pistol, DA CCW. (1.5 | 43) MAGISTER KNIGHT Panzerfaust, Light Shotgun / Pistol, DA CCW. (0 | 23) KAMAU (Multispectral Visor L2) MULTI Sniper Rifle / Pistol, Knife. (1.5 | 32) WARCOR (Sixth Sense L1) Flash Pulse / Stun Pistol, Knife. (0 | 3) MONSTRUCKER Submachine Gun, Chain Rifle, Drop Bears / Pistol, Knife. (0 | 13) TECH-BEE (Remote Assistant Level 1, Specialist Operative) Flash Pulse / Pistol, Knife. (0 | 5) HELOT MILITIAMAN Shock Marksman Rifle / Pistol, Knife. (0 | 13) 5 SWC | 300 PointsOpen in Infinity Army
    Or this:
    PanOceania──────────────────────────────────────────────────[​IMG]6 [​IMG]4 [​IMG]1 SERAPH HMG, 2 Nanopulsers / EXP CCW. (2 | 79) [​IMG] CRABBOT Flash Pulse / Knife. () KNIGHT HOSPITALLER HMG / Pistol, DA CCW. (2 | 39) KNIGHT OF THE HOLY SEPULCHRE (Forward Deployment L2) Spitfire / Pistol, DA CCW. (2 | 57) JOAN OF ARC Lieutenant MULTI Rifle, Nanopulser / Pistol, DA CCW. (+1 | 50) ZULU-COBRA (Sensor) Combi Rifle, Jammer / Assault Pistol, Knife. (0 | 29) KRAKOT RENEGADE Submachine Gun, Chest Mine / Pistol, DA CC Weapon. (0 | 15) WARCOR (Sixth Sense L1) Flash Pulse / Stun Pistol, Knife. (0 | 3) MONSTRUCKER Submachine Gun, Chain Rifle, Drop Bears / Pistol, Knife. (0 | 13) TECH-BEE (Remote Assistant Level 1, Specialist Operative) Flash Pulse / Pistol, Knife. (0 | 5) HELOT MILITIAMAN Submachine Gun, Light Rocket Launcher / Pistol, Knife. (0.5 | 9) 6.5 SWC | 299 PointsOpen in Infinity Army
  19. daboarder
    Whose giving your BS14 HI a 2/3 chance of getting free shots?
    Move-Move
