Hi everyone, been out of the loop for a while and I see that we have a new maghariba sculpt, what should I do with the old one that I have? Also where are the stats for Tariqa? Cheers
Continue to use the Magheriba Guard as a Magheriba Guard? The Tariqa is a Haqqislam flavored HVT, a Civilian that is involved with several classified objectives in ITS play. She has the stats of a normal civilian. http://infinitythewiki.com/en/Civilian_Rules
You can always buy the new Maghariba (which is an *awesome* model) and store the old one as a keepsake ;)
Whatever you like! It is still a legit model for a Maghariba Guard (and fluff-supported: it is the Artefaktech XCR-1 Bokbocegi, the new one is XCR-5 Akrep). Provided you have it on a correct 70mm base (as proper since N3 came out), you could field it in the Interplanetario itself, and no-one would even bat an eye. If you aren't too attached to it, you might turn it into a scenery piece. You can always make it a display model. Personally, I still hope there will be another Haqq multi-legged TAG available (years ago I had this vision of an outdated XCR-1 Maghariba being stripped down for an armored scout role in Khanate). Alas, that's my personal wishlisitng. But the ol' Maggie would make perfect sense there. Another possiblity is that RTF will have Maghariba Guard AVA 2. Having two different morels would be a plus then, wouldnt it? :)
Ramah Task Force is what was informally known as the Caliphate, the Vanilla/Red Veil starter is actually all RTF units, add in Naffatun, Maggie, Sally, Tarik, and Hakims as confirmed units (plus some others I've likely forgotten).
