Hacking and ZoC
Discussion in '[Archived]: N3 Rules' started by Hsien, Feb 18, 2020.
  1. Hsien
    Hsien Well-Known Member
    Hello there)
    I've got a question about hacking because there are a lot of threads without a clear answer on it.
    The main problem is this part of the rules -
    In this case, will ZoC of repeater allows a hacker to delay his aro with ss1? (Only Hacking aro or any aro(for example alert or change facing)
    Will ZoC of repeater allows a hacker to place Wight Noize during aro if someone(hackable/unhackable) activates in ZoC of repeater but without lof to the hacker?
  2. colbrook
    No, Repeaters only extend ZoC for the purposes of hacking, 6th Sense is not a Hacking skill/programme so can't be used through a Repeater.
    Yes, White Noise is a Hacking program and can therefore be used through a Repeater.
    Armihaul, DukeofEarl and Mahtamori like this.
  3. Mahtamori
    The asterisk to what @colbrook wrote is that Stealth doesn't work against models with Sixth Sense. This is a limitation of Stealth and works regardless of range or devices, so be careful when attempting to sneak through repeaters.
  4. Tom McTrouble
    I might not know new info but didn't IJW say before he thought you could delay in this thread:
    https://forum.corvusbelli.com/threads/repeaters-vs-stealth.22609/page-2
  5. Armihaul
    Armihaul Well-Known Member
    I don't know about that thread, but SS for delay is only in ZoC, and a repeater doesn't help with that.
  6. Tom McTrouble
    This was the original argument he postulated. Again dunno if it has been walked back.
  7. inane.imp
    It has not. It's moot, because nobody suggests it should be played that way.
    #7 inane.imp, Mar 1, 2020
