Gaia Switch and Disengage
Tema en 'Rules' iniciado por Stompburger, 24 May 2019.
  1. Stompburger
    Stompburger Member
    17 Abr 2019
    Scenario:
    Wild Bill is adjacent to an enemy Gaia and no other enemy. He spends a movement point to disengage, and succeeds. However, during the disengage roll, Gaia uses her ( :3:Displace an obstacle) switch to displace one of her Gorgoneions to a space adjacent to Wild Bill (before his disengage movement).
    Question:
    Does Wild Bill now also need to make a disengage roll against the the Gorgoneion before moving? Or does he move, and then if he is no longer adjacent to an enemy, no longer needs to disengage?
  2. Zewrath
    Zewrath Elitist Jerk
    28 Nov 2017
    This is the correct answer
  3. AdmiralJCJF
    21 Feb 2017
    There isn't another disengage roll needed for the first hex of movement.
    However, IF the Gorgoneion is adjacent to Wild Bill after he has taken that "first step" he may now need to disengage from that Minion.
    But you need to guess blind in placing the Gorgoneion, because Wild Bill gets to decide what direction to move in AFTER he has made his disengage roll.
    A Numazokola le gusta esto.
  4. Plebian
    Plebian Well-Known Member
    This often happens with 8ball and Max, where the Panda keeps dancing in front of him, very entertaining.
  5. Isidore
    Isidore New Member
    10 Mar 2019
    May-be yes.
    In the FAQ, from Aristeia website, we have this Q/A:
    Q: When making a Face to Face Roll to Disengage, what happens if I Displace myself with the effect of a Switch and end up adjacent to another Enemy? If the Roll is successful, could I move a space without having to Disengage this new enemy, or would I have to Disengage a second time without having moved? If I have to disengage a second time without moving, would I be forced to move 2 Spaces if I succeed with my second Disengage?
    A: The successful result when Disengaging forces you to move the Character that disengages, then the disengaged model must declare this mandatory movement and will have to make a new Face to Face Roll to Disengage the second model. If it’s successful again, the Disengaging Character must move only once.
    In the case describe by stompburger, wild-Bill doesn't displace, but have a new ennemy adjacent to him. Looks-like a lot to the FAQ situation...
  6. treiral
    treiral Midnight poster
    17 May 2018
    Controversial opinion:
    I never liked that FAQ. You're declaring movement twice, and rolling disengage twice, while successfully disengaging from one, but still can't move until you disengage from the second one. It breaks the rules of disengagement where it says "The active Character must move to a new space if the Disengage Roll is a success.".
  7. JAGS
    JAGS Member
    28 Abr 2019
    My Opinion and Interpretation: Doesn't matter where you end up with your displaces of switches, you just get a successful Disengage Roll and you should be able to move at least once... if then you end up adjacent to another enemy then i'm agree that you need to Disengage again, but it's like when you loss LoS with an enemy during an attack after switches, the attack resolves with the inicial condition.
    A AdmiralJCJF le gusta esto.
  8. AdmiralJCJF
    21 Feb 2017
    I see the similarity you are drawing, but would argue that the appearance of a Gorgoneion is sufficiently different that it doesn't necessarily follow the same logic.
    Nevertheless I stand by my original position. There isn't another disengage roll needed for the first hex of movement, but IF the Gorgoneion is adjacent to Wild Bill after he has taken that "first step" he now needs to disengage from that Minion.
