Sixth sense does not allow to delay ARO anymore, so we get new fun ORA with fireteam : A sphinx is in ZoC of 3 unhappy fusiliers (both in the same 5 man fireteam). Two fusilier (A and B) has LoF on him, the other no (let's call him C). First action : the sphinx declare move (stealth does not work due to sixth sence) Option 1 : all fusiliers declare dodge => No issue here Option 2 : fusiliers A & B declare BS Attack => No issue fusilier C want to declare BS attack but right now he is not fullfilling the requirement so : - C declare BS attack, it becames idle as he does not fullfill the requirement -C declare BS attack, ARO validity is checked at the resolution. It could became legal if the sphinx target Option 3 : fusiliers A & B declare BS Attack => No issue fusilier C declares dodge, leaving the fireteam. As he leaves the FT, he looses sixth sense and became affected by stealth. What then ? Does he loose his ARO ? Will he be able to ARO after the Sphinx second action
Not your question: Sphinx doesn't have Stealth, and this is intentional. Regarding your question: you leave the Fireteam because you declare a deviating ARO. If you are incapable of executing the ARO does not matter. In this case when the Generic Stealth Trooper executes the second Short Skill, which will likely be a Dodge or a BS Attack, the Fusilier's Dodge ARO would be valid when the Requirements are checked. If the GST executes another Move outside the Fusilier's LOF, the Dodge will be invalid and become Idle, but the Fusilier will still be out of the team.
