Using a Hirstarts.com mold, I cast blocks to build this Arcane Hexadome. They are 1.5 inch wide, so a little more spacious vrs the standard board. The initiative track slots can be seen in the corner of the board in the detail photo and the square indentations are designed to place 3d6, each die can be used to track energy use, movement points, and round tracker. The slots on the left are designed to hold the Aristo card upright for optimal viewing. I’ll post some picks of it in use when I test it out. The center scoring area is a separate piece that can be picked up and moved as the zone progresses in the game. The bloody blocks on the left is the infirmary and the blocks on the outside right serve as the bench.
