Can you use Explode LX if the only model\marker in range is a Camo marker? Normally you can only place a direct template after a WIP check (intuitive attack) Can you Use explode LX if there is an impersonator token in range? I'm assuming NO since its 'friendly', but thought I'd ask anyway.
http://infinitythewiki.com/en/Explode Following the Direct Template Rules, if the Circular Template of the explosion affects, for example, a Camouflage or TO Camouflage Marker without having a valid target inside the Template, or affects a friendly or Neutral trooper, then that explosion is cancelled and considered null.
