One of the abilities of an EVO device is described as follows: " An EVO Hacking Device allows players to spend a Command Token to re-roll an unsuccessful WIP roll when declaring the use of a hacking program. " Does this mean that this applies to any trooper of that army using a hacking program or only if the trooper with the EVO device uses a program?
You cannot spend Command Tokens unless it's Strategic Use, EVO "start with one EVO program when going second", or your Active Turn...
