[EN][ES] OCT'19 Painting group / Grupo de pintura
Discussion in 'Miniatures' started by Engorn, Oct 4, 2019.
  1. Engorn
    Rules:
    1) Post a picture of an unpainted/primed Corvus Belli miniature you pledge to paint.
    2) Paint it within the month, post your proof (PICS or it DID NOT happen).
    3) Rinse and repeat as much as you like.
    4) You can re-pledge a miniature next month if you didn't finish it.
    5) Enjoy and learn!
    Reglas:
    1) Postea una foto de la miniatura de Corvus Belli sin pintar o imprimada que te comprometas a pintar.
    2) PĂ­ntala dentro del mes, postea unas fotos del resultado.
    3) Pinta todo lo que quieras.
    4) Puedes repetir una miniatura si no la has terminado.
    5) Divierte y aprende!
    LeeroyVinland, Koin-Koin and jherazob like this.
  2. Oni
    Oni Well-Known Member
    Hi,
    My pledge for Oktober. Hope I can finish all three of them.
    The already finished ones from last month need company.
    Greetz Oni
  3. LeeroyVinland
    LeeroyVinland O-12 Agent
    Hey there,
    I'm gonna try to paint this 4 Yu Jing fellas from RedVeil within this month
  4. laguaridadekazan
    So, Here I am back again with my September goal.
    Standard colors, the ones from the box art. [​IMG]
    Oni and Engorn like this.
  5. Tasio
    Tasio Member
    IMG_20191022_085018.jpg Tres miniaturas de Nomadas a pintar con esquema basico, utilizando las contrast de GW y pinturas y tintas de Vallejo.
    Three miniatures of Nomadas to paint with a basic scheme, using the contrast of GW and Vallejo paints and inks.
  6. Koin-Koin
    Long time since my last attendance here but as promised to @Engorn I had to do something this month.
    So here is where Is was a couple of hours ago.
    And the result so far.
    Unfortunately the pic tend to tone down the contrast.
    Golem2God, Oni, Engorn and 1 other person like this.
  7. Tasio
    Tasio Member
    A medio camino...
    Halfway...
  8. Koin-Koin
    Unfortunately the unmasking phase ruined the previous work (plus I can't get rid of all the liquid mask).
    So the mini will be stripped.
    At least I know the scheme works.
  9. Anonymous
    Anonymous Guest
    @Koin-Koin did you varnish inbetween painting and masking? I've never done it myself but can see the potential
    jherazob and Koin-Koin like this.
  10. Koin-Koin
    Indeed I mat varnished it to protect the previous paint job. Maybe should I have use gloss instead but I'm not sure.
    When the paint ripped off, it was due to heavy rubbing (and maybe a bit of hanger).
  11. Anonymous
    Anonymous Guest
    Fair play, I only airbrush to base and do some limited highlighting and stories like this put me off doing anything flash :stuck_out_tongue:
  12. Koin-Koin
    Honestly, even if it's a fail, it's a good learning experience.
    I shared more detail here if you're interested.
  13. Tasio
    Tasio Member
    A falta de acabar las peanas.
    Finished in the absence of bases
  14. Engorn
    Hannibal for October.
    Hannibal para lo que queda de octubre.
  15. Engorn
    And done!
    Terminado!
  16. Oni
    Done.
    #16 Oni, Oct 27, 2019
