DT and datatracker's ways to kill it
Tema en '[Archived]: N3 Rules' iniciado por Ghost_from_warp, 12 Feb 2018.
  1. Ghost_from_warp
    Ghost_from_warp Classified
    25 Abr 2017
    A few questions about Datarcker killing DT
    1) Datatracker have Synchronized or Servant, Does DT killed by those Synchronized or Servant counts as killed by Datatracker?
    2) Datatracker places deployable weapon, which then cause wound and kill DT, does it counts that datatracker kill DT?
  2. borings
    borings Well-Known Member
    3 Feb 2018
    no to both. the kills would have to be from wounds directly caused by the DT model
  3. Tom McTrouble
    3 Ene 2018
    1. No, it is a seperate model from the DT.
    2. The way I look at it is thus: using a deployable weapon is an attack. So an attack is used by the DT, and the results of said attack cause a wound or wounds to be allocated to the Datatracker. So yes, it counts.
  4. daboarder
    26 Abr 2017
    Thats not how it works, the DT needs to be the one that causes the wound, not the equipment he placed. If the mine kills the target then the mine kills it, not the DT
  5. Tom McTrouble
    3 Ene 2018
    I would agree with you if a mine was classified as equipment, but it's clearly classified as a weapon, so it has to have a user. The weapon is used by the Datatracker, which causes a wound to the DT. The only difference between a mine and non-deployable weapons is that additonal actions are required for a mine to complete it's attack.
  6. daboarder
    26 Abr 2017
    Its a deployable weapon with its own statline, and disagree all you want but that was what HellLios was stating in the old ITS threads.
    http://infinitytheforums.com/forum/topic/50540-its-9-rules-questions-1-unanswered/
    For most of the answers, you'll note IJWs statement halfway down.
    "As per the existing discussions, a deployed Deployable no longer has any in-game connection to the trooper that put it down, apart from them being a friendly trooper."
  7. Barrogh
    Barrogh Well-Known Member
    26 Nov 2017
    Not to mention that a direct result of an Attack in which you plant a mine is a planted mine and not inflicted wound. That particular action by itself cannot result in dead DT.
    After that you have a separate object with its own statline, and the rest was posted above.
  8. Tom McTrouble
    3 Ene 2018
    Darnit I hate when I have to back down in the face of overwhelming evidence contrary to my beliefs. It makes me feel wrong as a forum user.
    A Papa Bey y T. Rex Pushups les gusta esto.
  9. Sabin76
    I mean, no one's forcing you to... there are plenty here that still hold true to the gospel of Forum.
    Forum 2:17 "Ye shall not back down in the face of overwhelming evidence, but shall persist until all others walk away in disgust. Only then shall you know that the argument is won."
    A T. Rex Pushups y Tom McTrouble les gusta esto.
  10. Tom McTrouble
    3 Ene 2018
    Blessed be the words of the Old Forum Testament .
    A T. Rex Pushups le gusta esto.
