I've been watching a lot of the Infinity battle reports on Beasts of War, and I really love the double-sided tokens they've used in several of them. Unfortunately I can't find anyone who sells them. Is that some custom thing they had and no company actually produces them?
There is an internet page at http://inf-dice.ghostlords.com/markers/ to make the tokens you need the way you want, and gluing some on both sides of the marker is quite easy. Personally, I have a ton of 1woun/unconscious markers, 3 Imp1/Imp2 etc... for my games :p
A good option is to have Regular Order/Unconscius markers (same for Irregular Orders). When a troop falls unconscius you twist the regular order token used from your order pool and put it on the model on Unconscius side, it's a fast way to count your orders in the next turn.
Those are my homemade tokes using either the card tokes from the starter boxes or ones printed out on 300gsm card. I put a 25mm epoxy dome one the front and then glue the tokens back to back using superglue. The domed surface makes the tokens very easy to pick up and attractive on the table.
This is EXACTLY the same that I do. It also helps transporting the tokens, as it only takes half the space
These are the type of self adhesive epoxy domes you want for the tokens. https://www.amazon.co.uk/Clear-Epoxy-Stickers-Adhesive-Bottle/dp/B071994MF6
It isn't. News will be when moderators can cope proactively. Meanwhile, just hit the report button and request things to move.
I do it for Camo markers (mines on reverse side), immobilised 1/2 and 1w/unconscious. Although sometimes a mine marker is just a mine ...
That one is a little "meh", since themines tends to never touch the table... besides, there are more camo deplaybles! (E/Maulers? XD), it's a good way to deploy unnumbered camo markers, then on the other side having deployables with a number... and sometimes those are troops.
I did a bunch of Prone/Unconscious markers. For when they may get healed they are then prone. Also Wound/Unconscious, Camo/Mine or other. They work great! Saves a lot of room for the case.
