Double Medkit & HI, akbar?
Discussion in '[Archived]: N3 Rules' started by kinginyellow, Jul 13, 2019.
  1. kinginyellow
    So, medkit success says to recover a wound and not go to 1 wound. Does this mean a link paramedic capable of shooting a unconscious or no wound incap 2 wound model such as a HI is capable of healing the model to two wounds?
  2. solkan
    solkan Well-Known Member
    From the yellow remember box:
    MediKits can only be used to heal friendly troopers in the Unconsciousstate, and they can recover only 1 point of their Wounds Attribute at a time. MediKits cannot heal more than 1 point of Wounds, and they have no effect on non-Unconscious troopers.
    So even if you had a double success on the medikit, it can’t restore more than 1 wound.
    #2 solkan, Jul 13, 2019
    ijw, toadchild and chromedog like this.
  3. kinginyellow
    Cheers, that's what I was missing!
  4. Ogid
    Ogid Well-Known Member
    btw, I've heard the failures cancel successes in the double medikit roll. Where is that explained?
  5. chromedog
    In the FAQ.
    Ogid likes this.
  6. toadchild
    As @chromedog said, but pasted here for the record:
    What happens when a trooper is hit by a MediKit (or Medjector) several times in one Order? For example by a Paramedic in a Fireteam that uses a MediKit remotely and hits more than once.
    As with MediKits in a Coordinated Order, each failure in the PH Rolls cancels one success. In the event of a draw, the target suffers no effect at all.
    Broadly the same thing has been held for things like coordinated doctor or engineer rolls as well. It's not spelled out in the rules, but it's the most consistent with the general resolution mechanics.
    Ogid likes this.
  7. ijw
    A Mão Esquerda, Ogid and toadchild like this.
  8. toadchild
    Ah, excellent! I had forgotten it was actually explicitly spelled out.
  9. Ogid
  10. Ginrei
    Ginrei Well-Known Member
    I don't see where any of these explanations definitively say each successful burst from a medikit is not added up or handled individually like everything else in the game.
    The Coordinated Order: Success + Failure says nothing at all about how to handle a result of two or more successes.
    The MediKit yellow box says it can only recover one at a time. To me that "at a time" is within the context of a single burst. Not a single order. Before fireteams this was always a one burst weapon.
    Side question, does a MediKit get the Fireteam burst bonus only when used remotely as a BS weapon? Or also when used in B2B as contact equipment?
  11. Ginrei
    Baggage explicitly states "This effect can only be applied to one friendly trooper per Order."
    I'd expect something similar if MediKit's were intended to work the same.
  12. Ogid
    It's kind of implicit, but a line clarifing that won't hurt tho.
    What happens here is that Medikit/Doctor doesn't just heal 1 W, its an ability with some limits: Only in Unconscious models, cannot heal more than 1 point at a time. So you have 2 effects doing the same at the same time, so one of them is redundant.
    It's kind of similar to Maestro/Hacking program that deals damage.
    https://forum.corvusbelli.com/threads/simultaneous-maestro-and-brainblast.25958/
    It's not the same case, nothing stop you to split the B and "heal" 2 units at a time if you use the medikit as a BS weapon; in fact in most scenarios it'd be better for you if you don't use the extra B of Medikit.
    toadchild likes this.
  13. toadchild
    MediKit and the normal doctor skill both take a wounds of zero and set it to one. Compare with engineer, which can increase your structure from X to X+1. Aside from the special case of Akbar Doctor, there is nothing in the doctor/medikit rules that allows you to end with a higher W value.
