    Dismiss Notice
Designated Target and Spec Fire
Discussion in 'ITS' started by Gunmage, Oct 17, 2019.
  1. Gunmage
    Gunmage Well-Known Member
    Designated Target rule has this:
    Does that mean that DT cannot Dodge vs Spec Fire, if the firer is outside of ZC and LoF?
  2. Armihaul
    Armihaul Well-Known Member
    correct, exactly as if you shot them from behind outside ZC
  3. Robock
    Robock Well-Known Member
    which is very different than normal models who do get to dodge if shot from behind outside ZC by a template weapon.
    so much different perhaps we should have a FAQ to fix it. As it is, it looks like a holdover from previous edition where being shot outside of ZC and LoF meant being unable to dodge the template.
    #3 Robock, Oct 17, 2019
    NorthernNomad and Hecaton like this.
  4. Hecaton
    Basically whoever wrote that rule didn't understand how AROs work in N3. Imagine that.
    NorthernNomad and Robock like this.
  5. Alphz
    Alphz Kuang Shi Vet. Retired.
    chromedog and A Mão Esquerda like this.
  6. xagroth
    I think they are stuck in the ITS document lines pointing that the HVT gets an ARO when the enemy spends an order inside of the Control Zone...instead of, for example, saying anything about treating him like an enemy trooper regarding AROs
    Gunmage likes this.
  7. Gunmage
    Exactly that. The line I quoted can be read as "HVT won't react to any Order performed by an enemy active trooper outside of its LoF or ZC."
    ...and some people do argue that's exactly what it says.
  8. Alphz
    Designated targets are considered enemy troopers.
    Impact templates give troopers AROs.
    It uses very similar wording to the base ARO ruless. Are they also saying troops can't react to spec fire because they're too lazy to read the rules in totality?
