Hey mates, just am somewhat confused, in this ITS Season AD Troopers can land without the template has to fit/be placed. Sooo how does the Bot of the Delta land? G:Servant says: G: Servant troopers possessing the Airborne Deployment (AD) Special Skill will be deployed with the same Order their Doctor/Engineer uses to deploy. In such situation, they must be deployed at the same time and on the same table edge segment, or the same Circular Template Any ideas? Am i also free to place him wherever i want? Thanks in advance :-)
As per G: Servant, you'll have to use the template. Just like you do if using Coordinated Order and Airborne Deployment.
My take would be: still take the template to get the 12cm range and then deploy both totally inside these 12cm. If you're fortunate enough to regulary use the metric system feel free to use your tape measure. Never mind. IJW has spoken :)
