Dazer limited by terrain?
Discussion in '[Archived]: N3 Rules' started by RogueJello, Mar 27, 2019.
  1. RogueJello
    RogueJello Well-Known Member
    Is the Dazer limited by terrain?
    It's unclear from the rules if it's ZoC template is limited or not by terrain. Could it be put into total cover, and effect something on the other size, or does cover cut off part of the template?
  2. TheRedZealot
    AFAIK ZOCs are not limited by terrain and so neither is the Dazer. It works a lot like a deployable repeater's hacking zone.
  3. ijw
    It's not a template weapon and doesn't have a blast focus, so there's nothing to limit it.
    RogueJello likes this.
  4. kinginyellow
    Is the limit of the where the terrain is, public information or is it best guesstimate until an action makes it public?
  5. ijw
    colbrook and locksmith like this.
  6. colbrook
    The rules for special terrain zones state they must be clearly represented in stone form, I plan to use a piece of string.
  7. kinginyellow
    Awesome, thanks guys!
  8. RogueJello
    Okay, sure. I'm mostly wondering because it's not clear how the effect is achieved, and Sci-Fi weapons, so it could be literally anything. While not a weapon, it could be that the effect travels out from a central point (like a disco ball), with terrain limiting it, or be generated everywhere. The addition of a token in the middle with a stat line that can be destroyed seems to point to central generator/disco ball. The rules just say ZoC, which is fine for a description of it's limitation of distance, but little for the things that might limit that. While it's true that I can't think of an example of ZoC which is limited by terrain or other LoF blockers, I also can't think of anything else that has a 8" range of effect either. Mines come close, but they have a trigger area instead.
    So I really find the current rules wording a bit vague, and adding a line about not being limited by terrain might be useful for other players.
    Anyway, thanks for the clarification.
  9. ijw
    Repeaters, Sniffers/Sensor and Nullifiers all have an area of effect of their ZoC, although it's only ongoing in the same way for Sniffers/Sensor and Nullifiers.
    By the rules it's just ZoC, plain and simple. Smoke Grenades require the blast focus rules to stop them doing the same.
  10. spears
    spears Well-Known Member
    As a number of deployables such as those are s0 is there anything that actually defines their base diameter and so zoc other than the 25mm convention?
    toadchild likes this.
  11. Robock
    Robock Well-Known Member
    huh, never noticed Sniffer is S0. But deployable repeater and nullfiers profile have then as S1. While a repeater itself and sensor itself don't have a targetable shootable profile, so would be zoc of the trooper that has those equipment/skills. I'm sure the SNIFFER Marker is 25mm, but some token suppliers might have 10mm versions and the wiki itself don't show how big that marker is.
  12. ijw
    All the official third-party ones are 25mm, with the smaller sizes used for status tokens.
    Robock likes this.
  13. Leviathan
    Leviathan Hungry Caliban
    small tangent: can i destroy my own Dazers if i decide they're no longer necessary?
  14. RobertShepherd
    No. You're never allowed to destroy your own equipment.
  15. ambisinister
    ambisinister Broken Zoetrope
    Unless it’s a Kuang Shi. You can blow them up whenever you wanr.
    (Sorry, I couldn’t t resist)
    Robock and Barrogh like this.
  16. Strapingyunglad
    I’m sorry if this is very obvious but I have been unable to find the rules for dazer in general. Judging by this thread it’s a deployable? Could someone point me to the rules for this weapon? Seems like army mobile just leaves a blank spot.
  17. ijw
  18. Nuada Airgetlam
    It's hilarious to me that a huge chunk of Ariadna is absolutely immune to Dazer :D
  19. Mahtamori
    They'll still suffer the Saturation Zone.
