Custom Token Sheet Creator - Updated for N4
Discussion in 'News' started by toadchild, Dec 5, 2017.
  1. toadchild
    I'll start with what's on the new official token sheet and work from there.
  2. Koin-Koin
    I've reworked a few from the official tokens pdf named V2 something.svg.
    Let me know if it's of any use.
    EDIT: I realised that text may be an issue for those without the font or just using a browser to display the SVG file so I made "Flat" file (text is no more text so can't be edited).
    #122 Koin-Koin, Sep 26, 2020
    Daniel Darko and toadchild like this.
  3. Koin-Koin
    Added a few ones.
    I noticed that the text's case is not consistent through all the token.
    Some use upper case while some use lower case. Not a big deal so I stick to upper case for everything.
  4. Thomashkis
    Thomashkis Active Member
    That's great to hear, can't wait!
    Lawson and toadchild like this.
  5. crouchingotter
    crouchingotter Well-Known Member
    Really looking forward to the N4 tokens being on the generator tool. It’s been an invaluable resource for me during the whole of N3.
    Thank you so much for all the effort you must put into this.
    Stiopa, toadchild and xagroth like this.
  6. toadchild
    I’ve been working with @Lawson to put together a generator for the custom token sheet, which is coming along nicely. Thanks for the patience, everyone!
    Red Harvest, Lesh', Brimat and 19 others like this.
  7. Urobros
    Urobros Well-Known Member
    Thanks to you, both!
    Xeurian, zapp and toadchild like this.
  8. toadchild
  9. Daniel Darko
  10. Uthoroc
    Uthoroc Well-Known Member
    This is absolutely awesome, thank you very much!
    Koin-Koin and toadchild like this.
  11. Stiopa
    Stiopa Trust The Fuckhead
    @toadchild, @Lawson, thanks a lot, both of you! This had to be a tremendous amount of work and will be very handy. You rock! :muscle:
    Some small suggestions after creating my custom token sheet:
    • 25mm Foxhole tokens would be useful
    • Power-Up colour might be green or blue to indicate it's a positive token
  12. toadchild
    I was contemplating that as well when I was putting the web page together, but didn't end up raising it. Technically this is an unnecessary marker, since the model being S3 is sufficient to remind you that it's in the foxhole state. However, it might still be nice to have a visual indicator that includes some of the bonuses that it receives.
    Stiopa and Mob of Blondes like this.
  13. Leviathan
    Leviathan Hungry Caliban
    Many thanks to you both for the awesome work you've done.
  14. Papa Bey
    Amazing work. Now all I have to puzzle out is what to double side with what! :(
    Koin-Koin, Daniel Darko and toadchild like this.
  15. Leviathan
    Haha doing the same thing! Can't decide if Regulars should be paired with Irregulars (for LoL) or Unconscious
  16. toadchild
    The thing to watch out for by making orders/unconscious paired is that you can sometimes have more orders than conscious models. For example, if a model dies on its impetuous order, or if you take a surprise missile launcher ARO on your first order of the turn, losing multiple models but only spending one order.
  17. Leviathan
    Yeah, i just printed off a bunch of extras using your generator :)
    Thinking ill back all the Irregulars with Unconscious too.
    Daniel Darko likes this.
  18. Lawson
    Lawson Well-Known Member
    Is the idea of a 25mm foxhole token so it can sit beside S3+ units that are in a foxhole state rather than underneath them (as I assume the typical Foxhole marker is designed to do)? I had just gone with the one size marker because that's the 'official' design.
    Re: Power-Up - I didn't go with green because that's the color reserved for deployables/equipment. Blue is reserved for positive states, and the way I see it, Power-Up isn't actually a state, so much as it is bonus Wounds if you happen to go above your maximum original HP... hence it being the same color as the wound tokens. In order to keep it visually distinct from the actual wounds, I went with a reversed color scheme on it (white border and red interior rather than the red border and white interior for wounds)
    Willen likes this.
  19. Uthoroc
    What do you use to print/build these as physical tokens? I like the heft and thickness of the CodeOne tokens and would love to approximate that quality at home.
  20. Stiopa
    Yeah, I always used small Foxhole tokens. My plan for N4 is to model all my units with Foxholes on 25mm bases, and use an additional 40mm base with some cover scenery on it to indicate Foxhole state, but I wanted to have additional tokens in my preferred size.
    As for Power-Up - I get the logic behind their current colour scheme, I'll just have to see if it works for me. I can always change the colour myself.
    Again, thanks a lot for all your work :)
    I print mine on a sticky paper sheets and stick them to standard bases. I also glued small magnets underneath the bases so they're magnetized.
    #140 Stiopa, Nov 9, 2020
