    Dismiss Notice
Custom Token Sheet Creator
Discussion in 'News' started by toadchild, Dec 5, 2017.
  1. Talus
    Talus New Member
    Could you please add a 22.225mm diameter size? I plan on using a button maker to my markers and that would be the perfect size for 1 inch buttons.
    hydra likes this.
  2. Contaminator
    Contaminator Brigadier of Baguette Brigade
    depending on your PDF software you should be able to scale your print job. So just increase your scaling a little. Also I used a 1 inch punch to make my tokens and it worked perfectly.
    Abrilete and toadchild like this.
  3. Papa Bey
    25mm works just fine for me using 1" actual tokens. It helps compensate for my shaky hand.
    toadchild likes this.
  4. toadchild
    That's a sufficiently precise and specific size that I don't think it's going to be generally applicable. Can you try the suggestion @Contaminator made and see if it's able to do what you need?
  5. Talus
    Talus New Member
    That sounds easy enough I'll give it a try.
    Thanks.
  6. fenren
    fenren Active Member
    @toadchild Just wanted to say thank you for sharing this tool with the community.
    I've used it to make more than a hundred custom tokens at this point.
    #46 fenren, Mar 12, 2018
    Melchior, volgo, Grimm and 2 others like this.
  7. toadchild
    I'm glad you've gotten so much use out of this! It's always nice to hear back from folks. :blush:
  8. Hecaton
    Any ETA on getting the Uprising factions' symbols added?
  9. toadchild
    I haven't had a lot of time for this stuff lately. It'll happen alongside me finishing up the MayaNet updates.
  10. Hecaton
    Cool! Looking forward to it.
  11. Contaminator
    @toadchild I wanted to thank you for this tool! I have made 4 sets of 100 tokens for different friends I have coerced into playing Infinity. Now they have full sets of tokens customized to their needs at a reasonable price. Saved us a lot of time trying to figure out which random dice means what in each given situation :stuck_out_tongue_closed_eyes:
    toadchild and jherazob like this.
  12. toadchild
    I'm glad it was helpful!
  13. hydra
    hydra Well-Known Member
    @toadchild :
    Thank you so much for this tool! I have used it so often, that I would like to contribute something to it. I know, It is not the style of the official token, but I have come up with a some Designs for the MetaChemistry Effects.
    If you like them, you could incorporate them into your creator.
    The grafics can be found here or I could send them to you, if you like.
    Anyhow, thanks again for thsi thing!
  14. Melchior
    Melchior Well-Known Member
    The token creator is really great
    Grimm and toadchild like this.
  15. toadchild
    Thanks, glad you enjoy it.
  16. Boardron
    Boardron Member
    Slightly related to this: I shamelessly copied the data pack design and turned it into a vector file for laser cutting. See PDF. Send me a PM if you're interested... I cannot upload the .svg file here.
  17. Drayton
    Drayton Well-Known Member
    You will add Tunguska / Ikari / StarCo tokens?
    :heart::pray:
  18. toadchild
    It is done!
    wendigo, Melchior and xagroth like this.
  19. Drayton
    Tnks :kissing_heart::stuck_out_tongue_winking_eye:
  20. HarlequinOfDeath
    Hi, G: MARIONETTE shows a Troupe Leader token in the PDF and Cybermines. Maybe worth updating for Tunguska. :grin: Thanks!
    toadchild and PauloCavalcanti like this.
