Hi, Can the forum settings be moved from a cookie storage to a profile storage? For instance, as I don't speak Spanish at all, I reduce all the Spanish dedicated sub forums. If I'm browsing from a different browser or from a private tab or a "delete cookies when closing" browser, I have to reduce the sub forum each time I launch it. I can live with that but having it on some other forums, I have to admit it's an enjoyable confort. Cheers, Koin-Koin
It would be nice. While you wait (>= eternity), you can check if all your browsers support extensions to force things, like GreaseMonkey. That's what I do, and not just for settings, but many other things. See https://forum.corvusbelli.com/threads/eng-esp-forum-tweaks-napas.481/ and use Code: // ==UserScript== // @name Fix CB layout // @namespace MoB // @include https://forum.corvusbelli.com/ // @version 1 // @grant none // ==/UserScript== document.cookie = "xf_uix_collapsedNodes=node_73%2Cnode_74%2c;path=/"; document.cookie = "xf_uix_expandedNodes=;path=/"; $(".node_44").insertBefore(".node_11"); to close both Aristeia and fix the order of Ejército Combinado (not useful for you). You would need to figure the node_X to close Spanish parts, which is the number at the end of the address (1 and 73, if I checked correctly, so above script but change 74 to 1). Edit: Typo.
