Hello, dear community! I might've read rules wrong, but from counterintelligence rule: Alternatively, this Special Skill counteracts the limit on Command Token use imposed by the Strategic Use of a Command Token, increasing it to two. Does it allows to use command tokens to remove adversary orders fwo times? i.e. remove 4 orders, 2 per token?
No. You can force your enemy, spending 1 command token, to be able to use only 1 command token in his first turn. https://infinitythewiki.com/Command_Tokens If the enemy has Counter Inteligence, that limit is increased to 2
Specifically this strategic use: The player who has the second Player Turn can make Strategic Use of Command Tokens in the Tactical Phase of the adversary's first Player Turn. By spending one single Command Token at the end of the adversary's Order Count, they can choose one of the following options: Prevent the adversary from using more than one single Command Token during that first Turn. If your opponent chooses this option Counterintelligence increases the limit to two. Counterintelligence has no effect if you are going second.
