So, making lists for an upcoming tournament a question popped into my mind. What happens when you coordinate multiple models with FastPanda or DropBear equipment and you want to use said equipment? Do Pandas and Bears need to have decalred same landing spot like with grenades? Maybe for Pandas you just declare when you deployed them (like with mines in Coordinated Orders) and then they can run off to their own directions? When it comes to Drop Bears I'd auggest dropping them all in the same spot and once you resolve throws move them to the closest possible spot in order (1st on the spot, 2nd i b2b with the 1st and next ones just as well) - tough that could break range increments when you toss a bear at 8" and the next lands a bit further because its the closest spot. What do you guys think about that? I'm hoping for some solid points, especially for Pandas.
Drop Bears would have to have the same target if thrown, so only one can ever be successfully placed even if all 4 members throw them (and all would lose ammunition). CKs don't have a target so you can coordinate placing several sets in standby.
