Coordinated order & stealth
Discussion in 'Rules' started by Arkhos94, Oct 16, 2021.
  1. Arkhos94
    A situation from our current tournament :
    2 tanko and a dayokai declare a coordinated order
    First skill : move
    Second skill : bs attack
    the tanko have LoF on the target but not the dayokai so the dayokai perform idle
    A guilang HD is in ZoC of the dayokai (but no LoF) can he hack him ?
    my hypothesis : the dayokai declared bs attack so he broke his stealth (as stealth is broken per déclaration) and can be hacked
    my opponent hypothesis : the dayokai performed idle so he is still stealthy and cannot be hacked
    #1 Arkhos94, Oct 16, 2021
  2. QueensGambit
    Good question.
    To me, it looks like the Dayokai has to declare BS Attack. From the Coordinated Order rule:
    "All participating Troopers must declare and execute the exact same sequence of Skills."
    "If any of the Troopers does not meet the Requirements of a Skill declared during the Coordinated Order, then they perform an Idle instead of that Skill, while the others may act normally."
    From the current Order Expenditure Sequence in FAQ 1.1.1, Requirements are currently checked at Resolution, not Declaration (even though almost all Requirements are known to be met or not met at Declaration).
    So it looks like the Dayokai has to declare BS Attack, and at Resolution we check the Requirements and find that, as we knew all along, he doesn't have LoF, so he performs an Idle.
    From Stealth: "If the user declares a Short Movement Skill or Cautious Movement within the Zone of Control of one or more enemies and stays outside their LoF, he does not grant AROs to those enemies." The Dayokai in this case didn't declare a Short Movement Skill (although he did, in the end, perform a Short Movement Skill), so Stealth isn't engaged.
    Arkhos94 likes this.
  3. Mahtamori
    The Daiyokai declared BS Attack, but performed Idle. Stealth cares about what you declare, it doesn't give a toss about what you actually do.
    https://infinitythewiki.com/Coordinated_Orders
    Under requirements, with bold emphasis added:
    Under effects, with bold emphasis added:
  4. colbrook
    In addition to the above, Idle does not have the Movement tag, so Stealth wouldn't work anyway.
    https://infinitythewiki.com/Stealth
    However, if the second Short Skill of the Order is any non-Movement Skill, then those enemies can react normally in ARO.
  5. QueensGambit
    Huh, interesting catch. I think "Movement Skill" here must mean "Short Movement Skill or Cautious Movement," not "Skill with the Movement label."
    Otherwise, a trooper would break Stealth by declaring Move+Discover, but not Discover+Move.
  6. colbrook
    That would also make Discover+Discover (against different targets) not break Stealth.
  7. Mahtamori
    I think that's a contradiction, because the bullet point before that says that Short Movement Skills will not cause the opponents in ZoC to gain an ARO.
  8. Arkhos94
    Small addition : the FAQ seems to confirm that what matters is the action declared (here BS attack), not the action performed (here idle) :
    If several Troopers are activated at once (for example a Coordinated Order or a Fireteam) and one of them uses Stealth while outside a reactive Trooper's ZoC or Hacking Area, can the Trooper that used Stealth be chosen as the target of AROs?
    Yes, but the ARO will become an Idle if the Stealth user does not declare a Skill that allows AROs.
