Colonel Ikari Conversion Ideas
Discussion in 'Ikari Company' started by Fathoym, May 20, 2019.
  1. Fathoym
    Fathoym Well-Known Member
    I've been toying with the idea of creating my own personal Colonel Ikari as a unique piece for the army. Currently, I'm thinking of using the old Mushashi and the Kempeitai from the Army Pack.
    I'm not really sure how that's going to work though, so I'm crowd sourcing some ideas.
    He needs to be;
    - Male
    - Brawler/keisotsu, cause you know, lieutenant
    My current thought is to use the upper body of the old Mushashi and the left hand - the one holding his wakizashi. I'm not sure how/if I'm able to incorporate the lower half of the kempetai though.
    Suggestions?
  2. Space Ranger
    I think a converted Colonel Voronin. sheathed Katana at his side, pistol in hand, add more hair.
    WarHound likes this.
  3. Ariwch
    Shikami with the head of bearded keisotsu/kesotsu hacker? Or Musashi's head.Or father Lucien Sforza as a basis...
  4. Fathoym
    So I've had a little play around with models I had lying around. This is a Ragik hacker with an army reposition. The hand was clipped and replaced with the Kempeitai left hand + sheathed katana. His head is the original Mushashi head, sawed off. Unfortunately the scale on the old model doesn't really hold up, but I need to do some green stuff work on the arm joins, so I will also try to bulk up the neck area a bit so he doesn't look so weeny headed.
    If that doesn't work, I will look to replace the head, but I dont really have anything suitable on hand at the moment.
    I think the Ragik is a pretty good baseline to start with - armoured enough to look like a brawler, and already equipped with a rifle + light shotgun.
    Sent from my SM-G960F using Tapatalk
  5. archangeleong
    Cool idea. Think he needs a beard though.
  6. Fathoym
    Yeah that's probably a good idea. Should help with bulking out the weeny headedness a bit. Let's see how sculpting that comes out though!
