I found this old(?) article: https://lonelyartichoke.wordpress.c...to-fix-close-combat-in-1-sentence/#more-24124 as i understand the the main idea is that beeing in base contact you have to use the cc attribute instead of PH to fix weird cc-experince. "... When declaring a Dodge or Disengage roll, the model must use the CC attribute, instead of the PH attribute. This simple rule has far-reaching changes on how everything plays. TAGs, Ninjas, mid-level HI and MI, everything. It massively pumped up the value of MSV on close and mid-range weapons, and massively (if not utterly) dumped on the ability of a 1-point Chain Rifle or Nanopulser to end a 40+ point CC specialist. Any trooper with high CC and any amount of Kinematika will radiate threat in the size of a small Circular Template. ..." what like to hear your opinion.
