Hello, Have a question about the new FAQ that says you can not cancel your camo as you like.... so how about if I want to control a Antenna with a TO/Camo/ Holo 2 and the Misson says in contact with, but not in Markerstate (like in Show of Force)? I can not chose to cancel my state and the wiki says only in contact with a model the state is canceled... a Antenna is not a model, right? So which legal action I can do to cancel my state to control this Antenna? Hope you can help me
See the Cancellation bullet points for each state. Typically, anything other than a Short Movement Skill or Cautious Movement will cancel it.
Not to go off-topic, but Holoprojector L1 still says that one of the cancellation conditions is if the model is discovered. That implies that you can attempt to discover any model to see if it's holoprojecting. Reading comprehension failure; you said "marker or model".
Entering base contact with a model cancels it. Given you need to be in B2B with an objective to interact with it and we need to treat some objectives as Troopers for certain purposes treating Objectives as models doesn't seem far fetched
