BS Attack (Continuous Damage) and Ammo Types
Discussion in '[Archived]: N4 Rules' started by Thule, Mar 11, 2021.
  1. Thule
    Thule Active Member
    If Padre-Inquisitor Mendoza shoots his MULTI Rifle with AP ammo, and the target fails the first save, does the continuous damage continue to apply the AP ammo effect to the target’s ARM?
  2. dhellfox
    i had the same question with the asrial a few months back, the answer was yes.
    Delta57Dash and toadchild like this.
  3. toadchild
    To further elaborate, if Mendoza crits with an AP + continuous hit, you would roll:
    • 1 AP save repeatedly until the target dies or passes
    • 1 single non-continuous AP save
    Continuous does not apply to the bonus save from crits, but AP applies normally.
  4. inane.imp
    What about DA?
  5. psychoticstorm
    Two armour saving rolls each failing can cause continuous damage causes continuous damage and a third armour saving roll that will not cause continuous damage.
    toadchild likes this.
  6. Thule
    Thule Active Member
    Translation: Crit saves do not trigger continuous damage. That makes sense.
    DA forces two saves on a hit; both of these initial, non-crit saves can cause continuous damage, but these CDam rolls do not cause two saves if failed?
    Assuming all saves fail:
    1 hit > 2 saves > 2 cont. dam saves > 2 cont. dam saves?
    Accidentally replied instead of edited, below.
  7. Thule
    Thule Active Member
  8. toadchild
    Correct, you get two saves off of the original hit, but those do not further multiply if they are failed.
  9. Thule
    Thule Active Member
    So, on-hit effects (two ARM saves, BTS+ARM save, etc) only affect the first save, any after that only apply effects like AP that modify ARM/BTS.
  10. toadchild
    That sounds right.
