Automedkit and Regeneration
Tema en '[Archived]: N3 Rules' iniciado por Husker34, 9 Abr 2018.
  1. Husker34
    Husker34 Member
    29 Mar 2018
    I can't find the rule that I think I'm looking for lol....but here goes.
    If I use regeneration on an unconscious model, lets say my Djanbazan, and I pass, does this cause an Aro if there are models that draw los to it.. Same question, I think would work for a Zaeydan with auto medkit.
    thanks in advance.
  2. solkan
    solkan Well-Known Member
    19 Dic 2017
    To use Regeneration, you declare that the unconscious model activates, spends the order, and declares the Regeneration skill. Doing all of that generates AROs as usual. Note that the Regerate skill includes bullet points which the Activation of the unconscious model, and the declaration of the skill possible, even though the Unconscious model normally isn't allowed to do that sort of thing.
    On the bright side, the model performing Regeneration is probably prone during all of this, so might be hidden from view more easily.
    AutoMediKit does the same exact thing (with the same ARO triggering), with a different name, as equipment.
  3. xagroth
    Yes, you have used an order and that generates ARO by the model who spends that order.
    For the unconscious model to not generate ARO you need a doctor or paramedic being the ones spending it ;)
    EDIT: Suggestion: throw smoke with your Yuan Yuan/Muttas so the Djanbazan has no one able to target him (unless MSV...), and remember Regeneration also grants inmunity to shock ^^U
    #3 xagroth, 9 Abr 2018
    Última edición: 9 Abr 2018
  4. Husker34
    Husker34 Member
    29 Mar 2018
    thanks!
    A xagroth le gusta esto.
