    Dismiss Notice
Arslan Conversion
Discussion in 'Druze Bayram Security' started by toadchild, Jun 22, 2018.
  1. toadchild
    toadchild EI Aspect
    I'm thinking about putting the head from the top-knot Ghulam onto a spare Druze body to make an Arslan. I have a Red Veil box I put together a while ago, but I can't remember if that model has the head as a separate piece or if it was cast as part of the body. Before I do anything rash, can someone please remind me if I'll need to cut things apart with tools?
  2. b1ackheart
    b1ackheart Well-Known Member
    The head was part of the body but should be simple with a razor saw.
    My WIP Arslan is a little complicated, using the multi sniper nomad grenzer, shortening the barrel of the gun and making a new muzzle break sculpting druze like armour over his knees shoulders and chest then using the corn rows and goatee aguicales head filling in the cornrows and adding a top knot.
    Sent from my SM-A520F using Tapatalk
    toadchild and McNamara like this.
  3. toadchild
    toadchild EI Aspect
    Thanks. I’m ok with doing some cutting, just so long as I know that’s what I’m getting into in advance.
  4. Gera
    Gera Well-Known Member
    which druze body you doing to be using?
  5. toadchild
    toadchild EI Aspect
    Currently leaning towards the old sculpt with a CCW. That kind of pose is easy to pick out as a "leader" model.
  6. Gera
    I thought about using Jethro, But I ended up headswaping him with the hacker head to make the druze sniper. Arslan currently isn't making it into any of my lists but i want to get a model for him up at some point.
    toadchild likes this.
  7. toadchild
    toadchild EI Aspect
    Putting the left over Druze helmet onto Jethro isn't a terrible idea. I'm currently using Knauf as my Druze sniper because 1. it amuses me and 2. I already had the model.
  8. Gera
    Then you will just need to convert a spitfire, which isn't too hard these days.
  9. toadchild
    toadchild EI Aspect
    What do you mean? Druze don't have a Spitfire option anymore these days.
  10. Gera
    Oh yes he has a multi rifle. I may be crazy
  11. toadchild
    toadchild EI Aspect
    Yeah, I'm still contemplating what, if any, gun swap to do.
  12. KedzioR_vo
    KedzioR_vo Well-Known Member
    @theGricks made the conversion that you're thinking about:
    And it looks cool. That DRuze definitely has the boss vibe ;)
    There's sure some cutting to do, but it's worth the effort.
    I myself went for a bit different head swap with some gun changing too ;)
    PozdRawiam / Greetings
  13. toadchild
    toadchild EI Aspect
    Yes, I definitely looked at both of those images when I was deciding what approach to take! I think both yours and the other look good.
