Antennas, Consoles and Tech Coffins
Discussion in '[Archived]: N3 Rules' started by Arkaon1125, Nov 5, 2019.
  1. Arkaon1125
    Arkaon1125 Well-Known Member
    In many scenario models like theese are used (as objective and so on). But wich is the base of such models?
    40 mm or 25? I saw the "token" template but somehwre i saw the 25mm option and somewhere the 40mm
  2. Hecaton
    They're all 40mm by default.
    chromedog and Arkaon1125 like this.
  3. Arkhos94
    All mission use 40mm objectives
    The only exception I can remember is looting and sabotaging which use a 25 mm objective
    It's not written in the ITS PDF anymore which size to use so : all kind of marker are 40mm except beacon who are 25mm (sadly you need to go to a third party website, like customeeple, to check their objective marker to have the base size)
    Edit : link to customeeple objective set so you can check base size : https://www.customeeple.com/product/infinity-its-objectives-set-14-units/?v=11aedd0e4327
    #3 Arkhos94, Nov 5, 2019
    Section9, Arkaon1125 and chromedog like this.
  4. HellLois
