Fairly new player and I've looked through the wiki and the forum, but couldn't find the exact text I'm looking for. If a figure is hit by adhesive ammo, where is it immobilized? I understand everything happens at the same time, but wanted to be sure. Take the example where a figure uses both short skills to move. Moves 4 and then moves 4 again, however it is in LOF for 1 inch of the movement. In ARO a figure glues the runner. Where is the runner glued? Thanks ahead of time for the clarification!
At the resolution of the order, so 'at the end point'. And this is how everything resolves in Infinity. If you get unconscious, would also be at the end point of the movement.
