Activating a switch for an ability that does not roll success
Discussion in 'Rules' started by Gabbi, Aug 21, 2021.
  1. Gabbi
    Gabbi New Member
    Is it possible to activate a switch for an ability that does not roll any :2: ?
    Or... if I roll a single :2: with Mendoza's Flamma Veritatis, can I use it to activate the switch instead of causing damage?
  2. Delta57Dash
    Delta57Dash Well-Known Member
    Yes, you can activate a switch even if the ability itself doesn't have any successes.
    Yes, you can spend the hits from Mendoza's attack to inflict burning instead of dealing damage. That's one of the reasons he's so good: even if your opponent rolls literally all shields, you can just spend any hits you rolled to burn them instead.
    Gabbi likes this.
  3. Gabbi
    Gabbi New Member
    Wait... :1: doesn't cancel :2: in any case? Like when a model tries to disengage, for example? If you spend them for a trigger :2: can't be cancelled?
  4. Kelthret
    Kelthret Usuario
    Switches take place before succeses get cancelled by shields. Also, using succeses in switches uses them, so, for example, if you use all of them to burn your opponent with Mendoza, or if you use them to mark your opponent while trying to disengage with Eclypse, you won't have any left to do damage/move away
    Croepoek and Gabbi like this.
  5. Gabbi
    Gabbi New Member
    Ah, right! Missed that. Thank you.
